IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
traction control light flashing
Old 01-03-12, 05:35 PM
k954triniz
k954triniz's Avatar
Default traction control light flashing
i have a 2001 IS300 auto ....
traction off light on cluster is flashing
recently bought the car
i wash out the air intake box not whole engine ..
and i also change rotors and pads ...
the light WASNT flashing before
Old 01-03-12, 10:03 PM
luis300
luis300's Avatar
check the fuse at the engine compartment it may be blow hope this help you.....
Old 01-04-12, 05:44 AM
cashed350
cashed350's Avatar
Trac light flashing usually means random misfire. Check your coil packs and plugs
Old 01-04-12, 06:22 PM
k954triniz
k954triniz's Avatar
ya tru that but its wuznt flashing before i change the brakes and wash those stuff
Old 01-05-12, 06:34 AM
dsouthmia0
dsouthmia0's Avatar
why dont you pull the codes at autozone or advanced and find out what the problem really is... just a thought
Old 01-05-12, 08:12 AM
bacon22
bacon22's Avatar
is ur check engine lite on too? every time my check engine lite comes on bcuz of a misfire the trac off lite flashes nobody knows why but it does. u should check ur spark plugs that u didnt get any water in there if u did thats ur problem but Dsouth mia is rite jus get the codes and then u can really know wats wrong P0133 is a misfire code for example.
Old 01-05-12, 10:17 AM
Lextrd016
Lextrd016's Avatar
Yeah man pull the codes but I asked the dealer about why multiple lights come on when engine check light is on he told me to get ur attention so u can bring it to the dealer..lol
Old 01-05-12, 01:23 PM
dsouthmia0
dsouthmia0's Avatar
yea that trac light flashes for almost everything
Old 01-05-12, 09:00 PM
k954triniz
k954triniz's Avatar
ya ima do that saturday .. this car is a lil touchy ... every thing is interconnected ...
my civic was wayyy similar lol
there is no check engine lite ... thats if it even works ... the guy own guyed it before seem like some who wud pull a fuse or something like that ... dont no how i got suckered into buyin this car
Old 01-05-12, 09:11 PM
k954triniz
k954triniz's Avatar
one more thing i forgot to mention ... like passenger side rear wheel bearing is bad( humming while i drive ..also both lower control arms are messed up .... now wrys those r being fixed on saturday )
can that affect it to
Old 01-11-12, 04:23 PM
k954triniz
k954triniz's Avatar
I fix the prob ... I bought electronics spray cleaner from radio shack ... Remove the MAL .. Spray the lil bulb lookin thing inside and also the connectors and reinstalled it ... Disconnected battery like sit for about 10 minute off .. Replaced ... Turn on car ... Light stop flashing and trac control works. Now .. So wen I makin a turn and press the gas I don't slide no more at least not as much ... Did it weekend pass its been 4 days and it works like normal
Old 01-11-12, 05:34 PM
g2096
g2096's Avatar
What is the MAL and where is it located?
Old 01-11-12, 08:49 PM
k954triniz
k954triniz's Avatar
oh im sry ... MAF -== mass air flow sensor ... that on your air intake ... has an approx 1 inch wide plug and has two small screws remove those and pull it off
Old 01-12-12, 06:53 PM
g2096
g2096's Avatar
oh ok, thanks...I have the same problem...I'll give it a try tomorrow and see if it works for me
Old 01-12-12, 08:31 PM
k954triniz
k954triniz's Avatar
ya man .. im not a genius on cars but this forum is helpful
Quick Reply: traction control light flashing
