Code P0442 - VSC, CEL & Trac Off Lights
Old 02-12-12, 10:55 AM
stranny
stranny's Avatar
Default Code P0442 - VSC, CEL & Trac Off Lights
Had oil changed a couple of weeks ago. Advance scanned codes - P0442. Guy said evap. leak in one of the vacume lines. Any ideas? Thanks.
Old 02-12-12, 09:37 PM
GS4_Fiend
GS4_Fiend's Avatar
What year is your car? Make sure your gas cap is tight. And reset the light see if it comes on again. Also check all vacuum lines thats EVAP related. They are under the hood and theres a vacuum diagram on top of the hood
Old 03-11-12, 03:30 PM
enigma9o7
enigma9o7's Avatar
I'm getting the same code on an 03.... already tried a new gas cap. For me it usually takes a week or two before it comes back after clearing the code...
There's also lines to the charcoal canister which isn't under the hood (it's by the fuel tank under the car) that could leak.
Anyone know how to find the leak?
Old 03-11-12, 05:13 PM
PFB
PFB's Avatar
The easiest and fastest way to find a leak in the Evap system is to bring it to a garage that is equipped with a smoke machine. Leaks will become obvious almost immediately.
Another possible cause is that you didn't tighten your gas cap after a fill-up, or your gas cap may be defective.
Old 03-11-12, 05:31 PM
enigma9o7
enigma9o7's Avatar
Of course easier to take to a shop, but trying to do this at home.
Where would they inject the smoke? There's this "evap service port" which says something about 1psi on it... maybe if I pump that up? But I'd assume there's some valves gotta be in the right positions too so I guess need to figure out how to open/close those as needed.
Old 03-11-12, 08:42 PM
GS4_Fiend
GS4_Fiend's Avatar
Unplug that line and insert the smoke.
CBSSYS
05-26-18 05:26 AM
davidyal
RX - 1st Gen (1999-2003)
08-10-17 03:51 PM
ChanceM40
11-23-14 06:36 AM
areukhmer
01-14-11 06:27 AM
Habious
08-13-08 08:01 AM
Quick Reply: Code P0442 - VSC, CEL & Trac Off Lights
