Fuel pump getting weak, how hard to change?
Old 02-18-12, 12:27 AM
ImWildBill
ImWildBill's Avatar
Default Fuel pump getting weak, how hard to change?
I have a 1990 LS 400, is the pump hard to replace in this car? I'm thinking it's in the tank, I've done fuel pumps before just not on the Lexus yet.
Old 02-18-12, 03:42 AM
LScowboyLS
LScowboyLS's Avatar
on a 95-97 it's easy, no need to drop tank, just have to remove trunk floor mat, trunk trim cover, seat cushion and back and then 8 bolts on the set plate on top of tank, 3 nuts on fuel pump bracket, disconnect hose and pull it out!
not sure if a 1990 is the same but I bet it is a very similar procedure
Old 02-18-12, 06:54 AM
Kansas
Kansas's Avatar
The location appears to be the same per the attached diagrams. You might want to check the fuel filter before replacing the pump.
Attached Thumbnails Fuel pump getting weak, how hard to change?-1990-ls400-fuel-pump-figure-1.jpg   Fuel pump getting weak, how hard to change?-1990-ls400-fuel-pump-figure-2.jpg
Old 02-18-12, 09:21 AM
JAndersson
JAndersson's Avatar
Maybe this information could help, http://www.lextreme.com/fp.htm
Old 02-18-12, 09:33 AM
AzHotLS
AzHotLS's Avatar
How do you know the fuel pump is getting weak? What symptoms are you experiencing? Could it be that you just have a clogged fuel filter that needs replacing?
Old 02-18-12, 11:27 AM
RA40
RA40's Avatar
What are the symptoms first?
Old 02-18-12, 10:23 PM
ImWildBill
ImWildBill's Avatar
The car has been harder to start the last couple weeks and now acts at times like it's starving for fuel when I hit the gas then runs ok. The other night on my way to work, I took the exit ramp off the highway and my car stalled out when I was almost stopped. It started back up and stalled again at the next light.
My Nissan did the same thing when the fuel pump was going out a few years ago. I'm planning on changing the fuel filter first then the fuel pump if it doesn't fix it.
Old 02-19-12, 05:25 AM
Kansas
Kansas's Avatar
I'd suspect other causes of this problem before the fuel pump - like the MAF.
Old 02-19-12, 12:13 PM
RA40
RA40's Avatar
Gas stateside isn't dirty with lots of particulates in it, I doubt a fuel filter. Any codes?
Old 02-20-12, 10:31 PM
Extrudedco
Extrudedco's Avatar
Have you tried bypassing the fuel pump resistor? It's fairly easy to test and could possibly be causing the problems you've described.
Old 02-24-12, 04:40 AM
ImWildBill
ImWildBill's Avatar
It isn't throwing any codes, it's been running rough for a few months now. I installed new plugs and wires and it helped a bit but not much. I was looking online for a MAF and they are almost $400 for what I've seen from a couple I found that were rebuilt.
I've been planning on changing the filter and pump before my son starts driving the Lexus here soon and doing the maintenance it's needed due to previous owner not doing maintenance or repairs on the car for several years. If it's still having issues after replacing the pump and filter I'm taking it in to get diagnosed so I'm not wasting money on replacing good parts....
Old 03-20-14, 03:25 PM
JHTJ
JHTJ's Avatar
[/SIZE]
Old 03-20-14, 04:50 PM
LScowboyLS
LScowboyLS's Avatar
on the 8 bolts, these have a very light torque of 29 inch pounds - that is just about 2.5 foot pounds, use a torque wrench meant for this range, or you will get it too tight and then the plate will be warped and you will never get it to seal and the inside of the car will smell like gas from now on!
message me if you need a high quality small torque wrench for this, I probably know of a deal on one!
Old 03-21-14, 05:52 AM
python
python's Avatar
ive yet to sell or even hear of a ls 400 fuel pump going out...doesn't mean it hasn't happened,but just like our master cylinders,they are very very reliable
Old 03-21-14, 09:50 AM
Shmee
Shmee's Avatar
Has the OP checked the fuel pressure specs as per the factory manual? Might be an idea before condemning a part and replacing it.
Hornet
11-21-15 08:31 PM
Qcollons
09-17-11 06:22 PM
fastlex99
06-17-09 05:40 AM
Bob'sSC400
Performance & Maintenance
12-22-07 07:48 AM
WVGS4
09-06-07 04:26 AM
Quick Reply: Fuel pump getting weak, how hard to change?
