Switched from Mobil 1 to Pennzoil Ultra
Old 03-03-12, 01:35 PM
LS430Lexus
LS430Lexus's Avatar
Default Switched from Mobil 1 to Pennzoil Ultra
Walmart was out of old reliable Mobil 1 and I wanted to get an oil change done. Plenty of other choices were available so the easiest thing to do was to make one. Pennzoil Ultra looked good so I bought it and the oil change is done.
Has anyone else used Pennzoil Ultra or Platinum and have you been satisfied? I change the oil every 5k on the 02 UL w/ 70k. I've used M1 since I got it at 50k (and on the LS400 before that). I tend to think the most important factor is the regular change with fresh oil.
Old 03-03-12, 03:37 PM
GS4_Fiend
GS4_Fiend's Avatar
In my experience, i've used Mobil 1 Full Syn for a few years and I notice it does burn oil a little. I then switch to Castrol Edge Full Syn, it doesn't burn oil anymore. But Pennzoil Ultra is fine.
Old 03-03-12, 05:00 PM
AlexusAnja
AlexusAnja's Avatar
If you were changing every 5000 miles... you're pure gold it's fine whatever you use...
Old 03-03-12, 06:16 PM
VNN326
VNN326's Avatar
MOBIL1 + OEM filter every 3k. why cause i love my car.
Old 03-04-12, 11:14 AM
chris81964
chris81964's Avatar
Mobil 1 OEM filter every 10000 miles. My Mercedes went longer and I had 250K miles on it.
Old 03-07-12, 08:35 PM
warminwisc
warminwisc's Avatar
I ran a Wally jug of Ultra in my LS when Valvoline was sold out. Noticed no difference in the car, then went back to Valvoline. Both oils where pretty clear at 7k. I will use like 1/2 qt or less, odo is 160k.
Syn oil is pretty price stable for last 10 years compared to dino oil where I remember quarts for often a buck or much less,69 cents even.
Fresh oil, keepin her clean and top tier tires make alot of difference.
Old 03-08-12, 03:39 AM
Muti007
Muti007's Avatar
Neither you or your car will ever notice any difference whatsoever.
Old 03-08-12, 01:52 PM
MEPEH
MEPEH's Avatar
So true guys...
read info on synthetic oils, replacing your oil every 3000 miles is only a harm to our enviroment...
Synthetic oils were designed initially for jet engines or engines that operate at about 60.000 revolutions... at 20-30k revolutions replacing the oil each 3000 miles is like changing your underwear each time you pee
Old 03-08-12, 03:41 PM
Jabberwock
Jabberwock's Avatar
Pennzoil Ultra gets lots of positive reviews on BITOG forum. Its avail at Wal-mart fairly cheap and I use it most of the time for my cars. Its supposed to have a really good additive package. Mobil 1 Extended Service also gets great reviews mostly on its additive package. Both these oils at 5k interval are likely overkill OCIs but for me its typically a twice a year oil change per car so the oil and filter cost is a nit so I stick to 5k intervals.
Old 03-19-12, 12:32 PM
Dirtyd210
Dirtyd210's Avatar
I have always used Penzoil Platinum synthetic ever since i bought my car w/120k on the dash. I switched to Penzoil Ultra the day it came out. I change oil every 5-7k miles and im almost at 200k now.. Still going strong.
In San Antonio, Walmart is the only place i can find the 5quart jugs, every other place only has them by the quart at 9.99+
MrNtIsF
IS F (2008-2014)
04-08-17 12:26 PM
LS430Lexus
01-18-17 11:00 AM
ak11
10-16-12 10:54 PM
LEXUSF
IS F (2008-2014)
13
03-26-09 01:52 PM
lexusam
05-18-07 06:47 PM
Quick Reply: Switched from Mobil 1 to Pennzoil Ultra
