Cigarette lighter & Power outlet not working -all fuses fine.
Old 03-05-12, 09:10 PM
Acer
Acer's Avatar
Default Cigarette lighter & Power outlet not working -all fuses fine.
The cigarette lighter and Power outputs not working on my 99 GS
I checked all the fuses in the fuse box (in the engine compartment,driver and passenger side) and all of them are ok. Is there an in-line fuse somewhere that might have blown?
Old 03-05-12, 09:22 PM
Chin
Former Sponsor
Chin's Avatar
There is a very small fuse at the base of the cigarette lighter, very small... You will have to remove it to see it.
Old 03-06-12, 05:55 AM
Acer
Acer's Avatar
I don't see any other fuse.What does it look like:?
Old 03-06-12, 04:10 PM
Acer
Acer's Avatar
Anyone?
Old 03-07-12, 05:10 AM
Acer
Acer's Avatar
need some help.
Old 04-26-12, 08:30 PM
kaosfive5
kaosfive5's Avatar
Hey Acer I'm currently having about the same issue, I only attempted to change the fuse on the passenger side kick but i notice people have mentioned there are multiple fuse box's (news to me) I just bought my GS last night and it was the first thing i realized after the fact. Oh well, did you have your problem fixed yet?
Old 04-27-12, 12:26 AM
hazepurple
hazepurple's Avatar
I have the same problem I've even bought a new cigarette lighter, still doesn't work, the one inside the armrest doesn't work either.
Old 04-27-12, 12:29 AM
hazepurple
hazepurple's Avatar
Hopefully someone can dial in about where the small fuse is, because it's been an annoying problem when I need my phone charged, I also don't remember seeing any small fuse
Old 04-28-12, 08:37 AM
kaosfive5
kaosfive5's Avatar
update::: I figured out my problem it was a fuse, apparently there are several fuse boxes. The one under the driver dash (behind the foot brake) ended up being the problem now its restored
Old 07-18-17, 05:51 PM
JflatChi86
JflatChi86's Avatar
Hello all, recently my cigarette lighter and console power outlet stopped working. I checked the fuses under the dash and those are OK and I pulled the lighter and power outlet and both of those have good fusible links. Is there a schematic of the electrical system somewhere? Whatever it is, it is most likely under the hood or in the dashboard somewhere. Thanks.
Old 08-04-17, 06:44 AM
Kretek234
Kretek234's Avatar
The fuse behind the foot break, you mean on the kick panel? I check mine and is ok, should I change anyway? Is there any other fuses somewhere related to the cigarette lighter, anybody? Take a picture please and thank you very much . I need help.
Old 08-04-17, 07:08 AM
Kretek234
Kretek234's Avatar
hi Chin, do you think you can a picture for the small fuse behind the cig lighter? Or diagram what is look like.
Thank you.
Old 08-06-17, 03:29 PM
Kretek234
Kretek234's Avatar
I check the fuse on the kick panel driver side and is OK, I check the power outlet under the arm rest and is working fine, but the cigarette lighter doesn't work.
I look at the manual, the cigarette lighter and the power outlet is in the same fuse.
Need help anyone, thank you.
Old 08-07-17, 08:11 PM
burteboy
burteboy's Avatar
How did you check your fuse, by looking at it? Best way is using a volt meter or tester light.
Old 08-08-17, 01:46 PM
AKGWBver2
AKGWBver2's Avatar
I am having the same issue....
Quick Reply: Cigarette lighter & Power outlet not working -all fuses fine.
