Jack and Jackstand Help
Old 03-16-12, 07:44 AM
TakaM
TakaM's Avatar
Default Jack and Jackstand Help
So my wife's car is getting pretty close to have to bleed the brakes. I've managed so far using ramps to change oils, filters, etc. but now I need to be able to lift her 2007 IS 250 RWD so that multiple wheels can come off. I have the Lexus Service Manual and it does show the jack point (front is near the oil pan at the cross member, rear is at the differential) with jackstand location at the pinch welds where the oem scissor jack is used.
With the above understanding and the fact I searched all over the place, I can't seem to get the good answer. Here are some questions and issues I'm hoping you can help out:
1. Jackpoint near the oil pan is too deep for standard hydraulic jack to reach. I guess I can put the car on ramp, or 2x4, or use the scissor jack but is there a better way?
2. Is there better jack stand location other than the pinch weld? I don't want to bend it.
3. I've seen some suggest the underside frame rail but I've also saw a post someone dinged it inwards towards the rear when used as a jackpoint since these frame rails in the rear are not doubled up with steel. Does this mean this is not a good spot for the jackstand?
4. Are there a specific jack stand that can accomodate the pinch weld location?
5. If pinch weld location is used for jacking or jack stand, should I be concerened about the plastic cover for the side skirt that is present? It appears there's a clip I can take off and bend that section out so that cover won't be used as part of the jackpoint/jackstand but it seems to be a hassel.
6. I came across this option but working underneath the car with scissor jack makes me nervous. What do you think?
http://www.optimaforums.com/forum/22...ssor-jack.html
7. I've seen a special jack that allows you to jack and then insert a special jack stand at the pinch weld section but the cost is $300/pair. Way too much. However, I'm willing to spend upto $100 if my current jack/jackstand won't work.
Thanks in advance for your help.
Old 03-16-12, 08:39 AM
Denver
Denver's Avatar
i've had that problem too. so i ended up jacking up one side first (hydralic jack on the weld and jack stand on frame) and then the other side. takes longer but thats the only way and you may bend the welds a little but thats normal
Old 03-16-12, 08:56 AM
greg0126
greg0126's Avatar
I do this as well. No problems yet.
Old 03-16-12, 09:00 AM
laobo979
laobo979's Avatar
All you need is a low pro hydraulic jack.
Old 03-16-12, 09:01 AM
TakaM
TakaM's Avatar
Double posted. See my correct post below.
Old 03-16-12, 09:03 AM
laobo979
laobo979's Avatar
You can Also put the jack stands on the lca also is what I do.
Old 03-16-12, 09:09 AM
TakaM
TakaM's Avatar
Thanks guys. This is helpful. Just to be absolutely sure, you guys place the jack stand on the rail bit inside of the car (where there is 2 inch wide frame going across the length of of the underside of the car)? As noted above, someone used this rail as a jack point in the rear and concaved it. jack stand will be ok?
Here's the image posted by another member per the manual. Jack stand would be placed not at the pinchweld location but the frame rail running parrel to the pinch weld?
Like this?
Old 03-16-12, 09:10 AM
Denver
Denver's Avatar
thats correct. take your time doing it and pay attention to what you are doing, if you never done this before
Old 03-16-12, 09:29 AM
TakaM
TakaM's Avatar
Lower control arm = the silver section at the bottom of this picture?
Old 03-16-12, 09:33 AM
TakaM
TakaM's Avatar
Just as an FYI, I've done lot of work on my Acura MDX including suspension work, tuning, etc. etc. It has 150K miles so I've done slew of things and am fairly mechanically inclined. Only thing I haven't done much is jacking up my wife's Lexus IS250 and I know today's unibody constructed vehicle is notorious to have not so strong frames where you can really screw up the car...hence all these questions.
Here's the image of what I'm trying to avoid:
Old 03-16-12, 10:39 AM
llamaboiz
llamaboiz's Avatar
I HATE putting my car on jack stands, our stupid jack points are wack~ Its like they don't want us to do our own maintenance~ WAS UP WIT DAT???
Old 03-16-12, 10:50 AM
Denver
Denver's Avatar
what car is this from?
Old 03-16-12, 12:20 PM
TakaM
TakaM's Avatar
I think it's the Lexus GS. Posted by another clublexus member.
Old 03-16-12, 12:30 PM
smokyis350
smokyis350's Avatar
When I first got my car, I tried to be extra careful by not bending the jack points. Now I don't even care anymore..
Old 03-16-12, 05:03 PM
IS250TW
IS250TW's Avatar
same here...
I mean our car isn't made out of paper.... so as long as you're putting the jack on the right spot
there won't be any problem
after coils installed, I didn't even bother to care about the jack points...
now they are all flat... hahah
Quick Reply: Jack and Jackstand Help
