Modified stock intake to sound like F-Sport intake
Old 03-27-12, 06:09 PM
On3racing
On3racing's Avatar
Default Modified stock intake to sound like F-Sport intake
My friend has an IS with an F-Sport intake with bottom housing piece and it sounded good too.
So....I was bored and decided to mess around with my stock intake. I cut out a 4x2" from the bottom housing, a little smaller than the F-Sport one just in case it might affect the MAS. So, far no light came on. Might try to enlarge the hole later and run an air duct hose from the intake hole to the lower grille for more direct cold air flow. I also took out the resonator from the tube and decided to wrap the tube since I had some thermal wrap laying around.
Anyways, let me know what you guys think of my homemade intake and the sounds it produces now?
And for the people who gonna comment "Why not get a real one?" .
First off, I do have the F-Sport filter tho.
Second, they don't make the F-Sport bottom housing for the GS.
Third, it's not like I can't afford the F-Sport or the Joe Z ones. I had the K&N intake and it lite my dashboard up like Christmas. Also, the low end acceleration has a stall before you go. but, it has a nice sound when you floor it.
Fourth, It was to see if I can can make one coz it's sucks that they don't have that much variety of intake or a true CAI for the GS.
This was a test run with the 4"x2" cut out.
<object width="640" height="480"><param name="movie" value="http://www.youtube.com/v/SKsODiE40Jw?version=3&amp;hl=en_US&amp;rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/SKsODiE40Jw?version=3&amp;hl=en_US&amp;rel=0" type="application/x-shockwave-flash" width="640" height="480" allowscriptaccess="always" allowfullscreen="true"></embed></object>
Can't seem to embed the youtube video
but, here is the link:
http://youtu.be/SKsODiE40Jw
Old 03-27-12, 06:34 PM
Mesca
Mesca's Avatar
SO dumb how they don't make a lower F-Sport box with the intake. I felt jipped a bit only receiving the intake and filter. Was there a noticeable sound difference? And no issues with acceleration or anything like that? Might give this one a try.
Old 03-27-12, 06:48 PM
On3racing
On3racing's Avatar
there is a noticeable sound difference at 3k and up or when floor it. Sounds like a cone filter intake.
No issue with acceleration in fact, it faster.
Check out this sound clip
Old 03-27-12, 08:28 PM
GS350Lexus
GS350Lexus's Avatar
WTF IS WITH THE RATTLE BOX????????????????? Anyways the tube thing wrapped why? The sound is alright but honestly I don't like mods that can't be reversed, well unless to buy a new intake box. The sound is alright slight change from stock. Well atleast in my case I drive a gs350. More important stop cutting holes and tackles those rattles ASAP, I wouldn't drive the car this way, can't do it man.
Old 03-27-12, 09:14 PM
On3racing
On3racing's Avatar
That rattle was coming from the camera that was mounted to the headrest. Yeah, that noise was annoying. This is my DD beater and I have an extra box if I wanted to go back or if I messed up, that's why I tried it too. The tube was wrap to keep the air temp down.
You can hear it suck in air (the grasp sound) and then the growl when you accelerate instead of the sewing machine whining sound . It sounds much better than stock. You have have to be in the car to really hear and feel it from the recorded sound.
Old 03-31-12, 12:38 PM
GS2100
GS2100's Avatar
Wouldn't raping the intake hose keep it hotter?
Old 03-31-12, 01:06 PM
On3racing
On3racing's Avatar
No, it's keeping the air inside the tube cooler. When I had the K&N intake the tube was hot to the touch. When I wrap the K&N and drove the same distance I took the wrap off and the tube was cool to the touch. I also use a Infrared Digital Thermometer to read the temp and it was significantly different temp.
The cooler the tube the cooler the air inside. This is my daily driver and I drive long distances for a long period of time. I also push my car hard most times too (heavy foot.)
So, every little bit helps.
Old 03-31-12, 01:53 PM
mynes09
mynes09's Avatar
Kool very nice sound...
Old 04-01-12, 04:05 AM
bigblack06
bigblack06's Avatar
This sounded real good man, not something I would dare to do but it def worked for you, what kind of strut mount is that and looks like you cut the engine covers to fit it,
Old 04-01-12, 12:40 PM
mreazn
mreazn's Avatar
Kinda off topic, but does that strut bar fit the GS350? And where can I get one? BTW that intake sounds pretty good!
Old 04-01-12, 04:56 PM
tbilisi79
tbilisi79's Avatar
I dont thing that strut sower brace is too effective. The way its designed just looks suspect. Bar has to be very rigid to even make a small difference.
Old 04-01-12, 05:15 PM
stvincent
stvincent's Avatar
i never understood why the 3gs doesn't come with a lower intake box.. but i didn't dare to cut or drill holes.. sounds good though, i can definitely tell the difference.
Old 04-02-12, 03:00 PM
sourwich
sourwich's Avatar
Can u show me how can i take resonator out.thanks
Hbhandal
Performance
25
02-20-14 01:45 PM
LexFSP350
Performance
16
01-04-13 01:03 PM
new.era.13
Performance
04-13-10 07:16 PM
andyboy
Performance
24
11-02-08 03:50 AM
iKenn
Performance
06-29-08 10:41 PM
Quick Reply: Modified stock intake to sound like F-Sport intake
