1999 gs300 radiator leak and overheating
Old 04-17-12, 11:10 AM
GS3TROOPA
GS3TROOPA's Avatar
Default 1999 gs300 radiator leak and overheating
well i was driving home from my girls house and all of a sudden i started smelling the sweet scent of burning fluids. and 10 seconds later the engine, oil, vcs lights turn on and my temp gage goes all the way cold and i started losing acceleration. I made it to the gas station and immediately turned it off. i can see that it was loosing fluid from under the radiator but could not exactly find the source.
i ended sitting for 45min and put like a gallon of water and it drove it home. it worked good the for the rest of the night. but after that it did the same thing with the smell and lights but the temp went past hot and then fell to cold.
what would be causing this and where do start to try and fix it?
Old 04-17-12, 11:50 AM
BDSL
BDSL's Avatar
Find the source of the leak first and replace the part.
Then fill the coolant and make sure there is no air in the system.
Old 04-17-12, 07:28 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
I concur....
it is obviously leaking from somewhere - find that somewhere, fix it, then you should be ok...
Old 04-19-12, 01:30 AM
ILOVEGIRLS
ILOVEGIRLS's Avatar
Follow the hose in and out to see where the leak may be. It could be a leak in one of those fat hoses or smaller hoses that pass through the throttle body. If I recall that's all there is.
Unless there is a small leak in the radiator itself... Look for water residue built up on the top of the radiator.
Old 04-19-12, 11:11 PM
GS4_Fiend
GS4_Fiend's Avatar
get the system pressurized, most effective way to find leak. bad radiator cap causes overheating also.
Old 04-20-12, 05:56 PM
GS3TROOPA
GS3TROOPA's Avatar
It looks like its coming from the bottom portion of the radiator. I think i gotta remove the fan assembly to see better.
Old 04-20-12, 06:00 PM
GS3TROOPA
GS3TROOPA's Avatar
How much does that cost. My moving expenses are killin me right now
Old 04-20-12, 06:38 PM
mitsuguy
mitsuguy's Avatar
$20 or so most shops... you can also buy a pressure tester for $60
Old 04-21-12, 10:57 AM
GS3TROOPA
GS3TROOPA's Avatar
I pulled the radiator and fan out. Decided to self test it for leaks. Covered all the outlets from radiator and filled with water and waited. Nothing was happening so i decided to lean it to one side and it started leaking from the top and bottom. So it looks like the o-rings need to be replaced.
Old 04-23-12, 07:37 AM
GS3TROOPA
GS3TROOPA's Avatar
i pulled the radiator and noticed there was a crack which i think caused the radiator appear to leak from the top and bottom. i ended up doing a self seal.
how long do those types of seals usually last?
Old 04-23-12, 11:12 PM
GS4_Fiend
GS4_Fiend's Avatar
you never fix a radiator. dont be cheap. buy another one, and go for aftermarket if you cant afford OEM.
Old 04-24-12, 04:07 AM
BDSL
BDSL's Avatar
Those seals are just temporary fix. No one knows how long they will last. It can give any second.
You should replace the rad soon.
Old 04-24-12, 12:53 PM
GS3TROOPA
GS3TROOPA's Avatar
alright then. going to be ordering one when i get paid and it should be here by the middle of next week. hope this seal can last till then.
Old 01-30-14, 04:21 PM
youngs3oo
youngs3oo's Avatar
My coolant started leaking recently also. Got home and checked to see if I can see where it was leaking from. There's water spots on the engine cover so I'm guessing it is happening on the top of the radiator. Looked under the car but cant really trace where it is actually coming from.
Should I go ahead and replace the radiator?
Old 01-30-14, 04:52 PM
mitsuguy
mitsuguy's Avatar
No, find where it is leaking from... Could be a pinhole leak in a hose spraying it, or the water pump and its getting flung around by the belt...
Quick Reply: 1999 gs300 radiator leak and overheating
