Timing Belt / Water Pump Replacement
Old 04-23-12, 01:39 PM
colenzae
colenzae's Avatar
Default Timing Belt / Water Pump Replacement
2002 AWD 195,000 miles
Need to replace my timing belt for the second time. I did not replace the idler pulley / tensioner or water pump the first time. What have other readers experiences been?? Do I replace the pulley / tensioner and water pump this time?? Can't see keeping this vehicle much longer; maybe another 50,000 miles at best. Part of me says if it's not broken, don't fixit but I think I'd be pushing my luck.
Old 04-23-12, 05:38 PM
sktn77a
sktn77a's Avatar
This question usually comes about on the first timing belt change where the response is mixed (but usually your "if it aint broke, don't fix it" response). At 200,000 miles, though, I'd be inclined to replace them while everything is torn apart.
Old 04-23-12, 05:48 PM
hypervish
hypervish's Avatar
I'd replace it, at 195k miles it's served you well.
Old 04-23-12, 09:04 PM
colenzae
colenzae's Avatar
Thanks for the replys. Any suggestions as to brands? Auto parts warehouse sells a Dayco kit that includes belt, water pump, idler pulley, tensioner, and adjuster for $265.
Old 04-23-12, 10:16 PM
salimshah
salimshah's Avatar
I would stick with OEM and my second choice will be at-least OES.
Salim
Old 04-24-12, 04:16 AM
carguy07
carguy07's Avatar
OE is so bullet proof, it would be hard to justify anything else in such crucial parts. IMO
Old 04-24-12, 08:27 AM
colenzae
colenzae's Avatar
Some parts are listed as OE replacement. Is that sufficient or am I looking for the exact phrase "OEM"??
Old 04-24-12, 04:22 PM
salimshah
salimshah's Avatar
OE replacement means exactly what it says ,,, the part would fit (read substitute).
OEM will come in Lexus or Toyota packing
When I states OES ... I actually wanted to say things made by the same manufacturer but not packaged for Toyota/Lexus. If Aesin (sp?) comes to mind for waterpump.
Just buy from CL sponsor and insist on OEM.
Salim
KimO
Maintenance
17
05-01-19 06:38 PM
RMalik
Maintenance
02-13-15 03:54 PM
iman61701
10-26-10 03:42 PM
Slvr surfr
09-20-10 11:00 PM
Quick Reply: Timing Belt / Water Pump Replacement
