Reaplcing side mirror LED
Old 05-19-12, 10:54 AM
LXurious
LXurious's Avatar
Default Reaplcing side mirror LED
Does anyone know who to acess the bulb that is under the under side mirror. The puddle light I believe?
LXurious is offline
Old 05-19-12, 02:13 PM
LEXUS714
LEXUS714's Avatar
push ur mirror so that u can pull it off and there is 4 phillips inside remove that and you should be able to access it... i did all my lights led a few weeks ago came out great
LEXUS714 is offline
Old 05-19-12, 03:16 PM
ekim
ekim's Avatar
What kind of bulbs are in the side mirror? 194 wedge bulbs?
ekim is offline
Old 05-19-12, 03:38 PM
Tee
Tee's Avatar
Man I love the search feature here on CL!
Originally Posted by HyperMKIV
thanks guys!!!
ok... since there's another thread asking about the puddles lights in the bottom of the side mirrors, i decided to make a quick DIY on this... specially since i had some LED's lying around. i completely forgot to take pics of the actually LED's i used...
anyway... so i moved both mirrors so they're facing all the way up... top all the way back and bottom all the way out... then i used my hands...no tools... to pry the corners closest to the doors...
http://www.youtube.com/watch?v=yF9_qo6kYuk
http://www.youtube.com/watch?v=QN33Tp763zw
then take out the 4 screws:
after you take out the 4 screws, the 2 housings will peel away from each other...
there's 3 tabs... one on the bottom and two on the sides closest to the car...then you'll see this:
take out the bulb from the housing and replace:
here's the units i replaced those with... (got them off amazon and the title was: 194 168 T10 Wedege SMD High Power LED HYPER WHITE BULBS Dome Lights 12V)
here's the finished result:
http://www.youtube.com/watch?v=K1CB8...ature=youtu.be
Please continue this discussion in thread below thx!
https://www.clublexus.com/forums/ls4...ts-to-led.html
Tee is offline
capt (03-21-17)
G-SharK
10-16-15 11:47 AM
Majek
03-27-15 08:14 AM
Sssky330
CT 200h Model (2011-2017)
01-07-13 08:03 PM
mccannt1
LX - 3rd Gen (2008-2021)
09-11-12 09:01 AM
2009is350
02-03-10 10:17 PM
Quick Reply: Reaplcing side mirror LED
