High pitch whistling/whining sound
Old 05-30-12, 06:29 AM
carlosL250
carlosL250's Avatar
Default High pitch whistling/whining sound
Good morning CL, I have recently discovered a new problem with my IS250 2008 AWD. Whenever I turn on my car in the morning, there's a high pitch whistling/whining sound that is continuously on until maybe after 5 miles of driving. After that it stays off until the end of my trip, but as I turn the car on and off it won't repeat the noise because I'm assuming that the engine is warmed up or something. Then if i leave the car for about 4 hours until my lunch time, it will occur again. I'm new to cars and its my first car so i have no idea whats wrong and whether something like this would be covered in the powertrain warranty since i have 61000 miles. Thanks for the help!
Old 05-30-12, 06:40 AM
Tony221
Tony221's Avatar
Hmmmm, sounds like it could be the belt or pulley/tensioner.
Old 05-30-12, 06:43 AM
skillvsluck
skillvsluck's Avatar
The whining sound is normal until the car gets to operating temp, i've noticed that its louder when its really cold out
Old 05-30-12, 06:52 AM
carlosL250
carlosL250's Avatar
No i think i know which sound you are referring to and thats the clicking sound of the engine which i found to be irritating in the beginning but i've gotten use to over time. This high pitched sound came recently. I'll try to get a video or sound file up for everyone to hear. Thanks!
Old 05-30-12, 06:53 AM
carlosL250
carlosL250's Avatar
would something like this be covered by lexus powertrain warranty?
Old 05-30-12, 08:12 AM
skillvsluck
Got ya....just take it into the dealer, that should be covered under powertrain warranty.
Those aren't wear and tear items like brakes or tires u kno
Old 05-30-12, 02:28 PM
carlosL250
carlosL250's Avatar
Ok i called the dealer and they are saying that it sounds like the drive belt, which they recommend to change every 60000 miles, which is pretty much where i am at. They quoted me around $200 all together, and obvious there's nothing final until they actually inspect it which alone cost $135. Plus they said that this wasn't under warranty because it's wear and tear.
What should i do?
Old 05-30-12, 03:02 PM
Kurtz
Kurtz's Avatar
A drive belt is $27
http://is.sewellparts.com/accessorie...2008/2057.html
If that's the actual problem then just order one and put it on yourself, it's pretty easy and a lot better than paying over 6 times that at the stealership (and yeah, the drive belt itself wouldn't be under powertrain warranty)
Old 05-30-12, 03:24 PM
carlosL250
carlosL250's Avatar
Originally Posted by Kurtz
A drive belt is $27
But how do i know exactly what the problem is? how do i tell if its a drive belt problem?
Old 05-30-12, 05:16 PM
Gville350
Gville350's Avatar
Have you ever turned the car on, took a look/listen under the hood, and didn't drive it. Does the sound still exist until the motor warms up?
Old 05-30-12, 07:37 PM
FNFZ4
FNFZ4's Avatar
while its whisling open the oil filler cap. if the sound disappears its the PCV valve
Old 05-30-12, 07:56 PM
carlosL250
carlosL250's Avatar
Is this covered under powertrain?
carlosL250
carlosL250's Avatar
I will try this tomorrow morning.
Old 05-31-12, 04:49 AM
My0gr81
My0gr81's Avatar
could also be coming from the emission control air pump and/or hoses as those are only active when engine is started cold or during cold outside temperature.
Old 05-31-12, 08:09 AM
UniSlayEX
UniSlayEX's Avatar
I would have also thought it was the belt. I would order the part from Sewell and take it to the stealership to lower the cost.
Quick Reply: High pitch whistling/whining sound
