Radio doesn't work, door ajar light on
Old 06-04-12, 05:33 PM
ChrisRose8
ChrisRose8's Avatar
Default Radio doesn't work, door ajar light on
The other day I was driving and my radio/cd player was turning on and off by itself. So after sitting for about an hour I went to drive it again and it started but the engine killed; I was unable to shift gears at all. I was unable to start the vehicle after that, the battery was dead. So I jumped it and it started but then killed after a moment so I suspected that the alternator was bad. Long story short I had that tested and it was fine, found out that a fuse was blown. the 120amp ALT fuse. So $4 later it was up and running just fine. Except now my stereo does not turn on at all, and when I shut the car off and close the door my door ajar light comes on and stays on. (yes I've checked all the doors) The door ajar light is not on when the car is running though. Any ideas here? because I'm at a loss
This is a 1996 Lexus LS400 with just under 150K miles.
Last edited by ChrisRose8; 06-04-12 at 05:45 PM. Reason: forgot to put make/model of my car
Old 06-08-12, 10:10 AM
ChrisRose8
ChrisRose8's Avatar
Default '96 LS400 Radio not working!
Is it common for the Nakamichi radio to just stop working?
With mine its like there is just no power going to the stereo. I checked the fuse and it was blown; I replaced it with the proper 20amp fuse and still nothing. I pulled it out and checked all the rear connections and they are all fine as far as I can tell.
Old 06-08-12, 01:16 PM
LSTex
LSTex's Avatar
Did you check all 3 fuses? According to the schematic, there are 3 fuses that power the radio. (One is just the illumination, but why not check it too?)
The Dome Fuse (10A) and Radio Fuse 1 (20A) are under the hood. Radio Fuse 2 (15A) is in the driver's side Fuse Box under the dash, above and to the right of the parking brake pedal.
Old 06-09-12, 11:08 AM
ChrisRose8
ChrisRose8's Avatar
I honestly didn't know that set of fuses even existed in my car...But I checked them and they were all fine. The inside of the fuse cover says that its a 7.5am fuse for radio 2. Either way it was fine. So I really have no idea
Old 06-10-12, 09:07 AM
LSTex
LSTex's Avatar
I was checking around for similar problems and came across this...
http://us.lexusownersclub.com/forums...howtopic=70269
Evidently, some people have had problems with the stereo going into mute mode. Hopefully, that'll be of some help.
Old 06-10-12, 12:28 PM
Kansas
Kansas's Avatar
When you "checked all the rear connections" did you check the pins for power? I'm trying to understand which side the problem is on - radio side or harness side. Anything happening on the radio display? Do the radio buttons light up when the headlights are on?
If the radio display "works" (displays station frequency) then is there any evidence that a phone system was ever installed - e.g. a phone controller on the left side of the steering wheel.
Old 07-14-12, 10:02 PM
nyjdmevo
nyjdmevo's Avatar
Default did u fix it
have the same problem radio dont work and door ajar stays on ???? radio fuse in dash and hood look good
Old 07-16-12, 05:27 PM
ChrisRose8
ChrisRose8's Avatar
Default fixed it
Turns out that the power cable for my stereo was bad. I got a new stereo installed anyways along with a new cord and it works great. Door ajar light is no longer on.
Old 07-16-12, 05:29 PM
ChrisRose8
ChrisRose8's Avatar
Sorry for the late reply. But it turns out that it was the power cable that was bad.
Old 11-11-16, 01:32 PM
mary94123
mary94123's Avatar
did you fix yours? was it the same fix as chrisrose8?
I have the same door ajar indicator & dead radio problem on my 1997 LS 400.
Old 11-11-16, 09:20 PM
dicer
dicer's Avatar
The first guy here said when running the door light is out, only when its not did it then come on. So that is likely something to do with the door / security system ecu or the other module that I read some place that Yamae had mentioned. You will need to find some good service info about that year car because all the systems are CAN based.
The Toyota tech site will have the info, or go to a dealer and ask to look at the service manual. Seems funny a power wire just goes bad for no reason, something else had to be going on.
Old 05-12-18, 09:29 PM
jamesdean9
jamesdean9's Avatar
Default need help with my 96 ls 400
does anyone know what would cause the radio to go dead and keep the door ajar light on only after I turn the car off also the trunk lamp and lights in the back seat do not work either it was working fine then just shut down all at once
RodF
06-13-13 12:00 AM
VSRgs300
GS - 1st Gen (1993-1997)
11-03-12 05:15 PM
Is300Tree2
09-03-10 03:03 PM
TXFM
12-10-08 02:07 PM
nate811
RX - 1st Gen (1999-2003)
05-26-08 08:36 AM
Quick Reply: Radio doesn't work, door ajar light on
