Mark Levinson sound system
Old 07-01-12, 09:59 AM
obojohnson
obojohnson's Avatar
Default Mark Levinson sound system
Does anyone know a good place to get speakers and parts for a Mark Levinson sound system that would be more reasonable price-wise than a Lexus dealer?
Old 07-01-12, 12:35 PM
VVTiBob
VVTiBob's Avatar
Depending on the damage many here have found speaker repair, instead of replacement more than reasonable. There is a long history of issues with the door woofer, ans the sub woofer too. Some have opted to replace them with other brands but run into issues with correct Ohm ratings, others, like mine were covered under extended warranties. If you search in the forum, or google the net for speaker repair you find info on that option. I got my old speaker back after it was replaced and had it repaired and now have it as a spare if the other fails. The repair was $35, with them doing the work, less if you do it yourself...either way it more reasonable than the $250 Lexus wanted along with another $200 in labor to take it out of the car.
There are several well documented threads some with photos on how to get the speakers out of the door panels.
Oh, BTW welcome to the forum...the search and Advanced Search tool are very valuable when looking for info in the forum.
Old 07-01-12, 03:38 PM
Jefff1
Jefff1's Avatar
Do the MB Quart speakers work as replacements for the ML speakers?
Old 07-01-12, 04:06 PM
VVTiBob
VVTiBob's Avatar
I am not familiar with them, but there are two areas of concern when looking for replacements... The ohm rating and the physical depth of the speaker. The door woofers are 8 ohm speakers which is unusual for car systems. Using the wrong ohm rating can potentially lead to amplifier issues. The second issue, depth of the speaker, is in regards to the window clearing it. Many replacements are too deep, blocking the window.
Here's a recent thread to read through on the topic: https://www.clublexus.com/forums/sc-...xus-sc430.html
Old 07-01-12, 05:35 PM
Jefff1
Jefff1's Avatar
Thanks for the help Bob....I'm glad you own a 430
Old 07-01-12, 09:53 PM
73446's Avatar
Here's the url to the thread where I, with the help of Bob, Habeas and others from this forum dealt with the 6x9 door speaker issue, including costs to repair.
https://www.clublexus.com/forums/sc-...n-success.html
After shopping long and hard, and having a few extended conversations with a high-end stereo guy here in Sacramento, CA I decided against replacing the speakers with another brand. Bob is right...your amp will overheat with speakers that aren't 8 ohm. I decided to have them repaired and I'm very happy with the results.
Mike
Old 07-07-12, 12:03 AM
garybc230
garybc230's Avatar
I to had the same problem when I purchased my SC this past May. I took mine to the BB to have a remote start put in and they removed the speakers and I ordered the speaker rubber replacement kit, They did the work and put them back in and they sound great. I wouldn't do the work yourself unless you are able to get them perfectly air tight. The kit cost $24.95 for the 2 6x9 front speakers and included free shipping. The only other cost was labor and that was a simple speaker install. Good luck.
Old 07-07-12, 05:21 AM
jfmjr
jfmjr's Avatar
Had all speakers rebuilt 2 years ago and could not be more pleased. The total cost was less than $200.
Old 07-16-12, 03:35 PM
fubie
fubie's Avatar
I replaced the door woofers with these and have been very happy. They fit and are 8 ohm speakers. http://www.simplyspeakers.com/replac...er-w-6028.html
Old 07-16-12, 03:59 PM
robertrios
robertrios's Avatar
You can buy replacements off Lexus Sewell Parts, create an account using your Club Lexus user Id and you qualify for some great discounts. These would be more than some of the options presented by other members but they will be new OEM replacements.
Old 07-16-12, 08:03 PM
73446's Avatar
Thumbs up Good Show!
fubie--it's good to know that there are replacement speakers for a reasonable price! Did you do a google search to find them? I'm curious because I looked for quite a while and just couldn't find 8 ohm speakers that fit and let the window function.
Mike
Old 07-22-12, 12:14 PM
bacardi
bacardi's Avatar
i use the 6x9 DC Gold speakers for the front woofers.
Old 07-24-12, 09:17 AM
barncat
barncat's Avatar
Did these require any modification to fit?
Old 07-24-12, 10:24 AM
bacardi
bacardi's Avatar
no they are a bolt in and also marine speakers 8ohns 6x9 and a great speaker, great sound.
Old 07-28-12, 09:46 AM
73446's Avatar
Default Link, Please!
@ bacardi...can you post a url link to the speakers? I'm curious...
The more options we have in all price ranges, the better!
Mike
cory143
06-15-14 09:39 AM
sjl
12-26-10 07:13 AM
Ventura
05-12-10 07:48 PM
GS430V8
08-25-08 01:59 PM
Quick Reply: Mark Levinson sound system
