Old 12-15-14, 04:02 PM
How-Tos on this Topic
Last edit by: IB Advertising
  • Warning Lights
    Important information to help you understand your Lexus
Browse all: General Overview
Print Wikipost
Dash warning lights help.
Old 09-26-12, 06:37 PM
rodallg
rodallg's Avatar
Default Dash warning lights help.
Trying to troobleshoot my daughters 2006 IS 300 that at random times while driving the following lights/indicators come on and stay on until the car is shut off, when it is started back up they ared clear. The lights are , slip indicator, master warning light, abs warning light, brake system warning light, and the check VSC message.
I was going to hook up my ultra gauge I have in a different vehicle and read the codes but I'm not sure if they would be cleared when the car is shut off or they would be recorded since they clear themselves on the power cycle.
Any ideas what would be causing this problem?
Thanks
Old 09-27-12, 04:46 PM
rodallg
rodallg's Avatar
Any help???
Old 09-27-12, 05:13 PM
nitrotang
nitrotang's Avatar
That's quite obviously not normal. I would just bring it into a dealer to have it checked out. And take a picture of all the lights since it seems to reset every time you turn the car off.
Old 09-27-12, 07:22 PM
diagtime
diagtime's Avatar
codes should not be cleared. those lights will all come on for any check engine light. let us know what codes are stored
Old 09-28-12, 02:15 AM
CLIS250
CLIS250's Avatar
do you have any thing tapped directly to the battery such as a wire harness or subs or anything?
Old 09-28-12, 06:46 PM
rodallg
rodallg's Avatar
Nothing attached to battery.
The oi was changed today and the dealer said the battery was down in voltage. It starts fine and charges (I checked with meter), I'm wondering if that could be causing it.
Old 09-28-12, 06:47 PM
rodallg
rodallg's Avatar
I will hookup the ultragauge this weekend and let her drive around and see if I can get the code(s).
Old 09-28-12, 09:43 PM
diagtime
diagtime's Avatar
if your diagnostic equipment can read codes in history, they're probably still there.
Burroo67
11-08-18 03:50 AM
harmonytom
ES - 5th Gen (2007-2012)
05-06-15 05:20 PM
njmurvin
02-04-09 12:45 PM
v1nnie
01-31-08 07:34 PM
Lexs400
01-08-04 04:29 PM
Quick Reply: Dash warning lights help.
