What did you do to your LS400 today?
Old 11-03-12, 12:27 AM
  #151
hotdawwg
hotdawwg's Avatar
Yeah I guess... It was weird... I was driving on the 15 going to Vegas and the trains just acted like it wasn't engaged into drive as if it poped out of gear... It did it 3 times before I had it towed back to Fullerton and my buddies shop. We cracked it open today and the fluid was stinky burnt. Fluid was light red compared to dark red like Toyota IV is supposed to look... After I pulled the Trans cover off I noticed the filter was hella dirty. Took it off and tried to clean it but no, so I went and got a new one for $17 and replaced the fluid after I put the cover back back on... I will double check tomorrow to make sure it is full... So far it drives good but we will see....
Old 11-03-12, 10:41 AM
  #152
Dranom
Dranom's Avatar
Damn! Good luck bro! Hopefully it doesnt act up anymore
Old 11-03-12, 02:06 PM
  #153
Ls400RR
Ls400RR's Avatar
A lot of buffing
Old 11-03-12, 02:33 PM
  #154
SpencerT
SpencerT's Avatar
Tried to fix my speedometer.
It had the common problem of sticking at zero.
About 6 months ago, I installed pins to keep the needle from ever hitting zero.
They have never stuck since but...
Tach worked perfect. Speedo was 15 mph fast ever since.
Today I installed new pins, closer to zero for the speedo. Then started the car and reset the needle at zero hoping that I had solved my problem.
Speedo is now 7 mph fast... fml
All I suceeded in doing was to make my math more difficult to determine my actual speed.
Atleast my needles dont stick anymore...
Old 11-03-12, 02:42 PM
  #155
E36M3
E36M3's Avatar
Well the bright side is no more sticking needle.
Old 11-03-12, 02:55 PM
  #156
SpencerT
SpencerT's Avatar
Yea, its an improvement for sure. Ill get it right eventually.
It is just such a pita to remove the cluster to work on it.
To anybody with my original problem of sticky needles, I would be glad to give advice because I have been there and done that. Multiple times.
Old 11-03-12, 03:39 PM
  #157
Dutchy
Dutchy's Avatar
yesterday i bought a set coilovers second hand for a nice price. Next weekend i will install them on my work if i have the time for it
Old 11-13-12, 09:42 PM
  #158
DertyDOH
DertyDOH's Avatar
put in phillis clearvision bulbs into the stock housings today, made a huge difference, only $25 via amazon, getting the corner lights out was a huge pain though
Attached Thumbnails What did you do to your LS400 today?-img_20121113_184742.jpg   What did you do to your LS400 today?-img_20121113_184750.jpg   What did you do to your LS400 today?-img_20121113_184757.jpg
Old 11-14-12, 09:30 PM
  #159
Dranom
Dranom's Avatar
Washed my car since it was dirty but Looks like it might rain this weekend so FML -_-
Last edited by Dranom; 11-15-12 at 04:05 PM. Reason: bad, censor is there for a reason. :|
Old 11-15-12, 03:53 PM
  #160
Sc0pe
Sc0pe's Avatar
Well, we bought it, if that counts
Old 11-15-12, 10:11 PM
  #161
E36M3
E36M3's Avatar
What did you buy?
Old 11-16-12, 07:45 PM
  #162
Sc0pe
Sc0pe's Avatar
What did you buy?
The car itself Refer to my sort of intro/build thread if you want to see more.
Old 11-17-12, 12:33 AM
  #163
IBOO57
IBOO57's Avatar
Gave the Celsior a Polish today. My arms munted but it looks good now!
Old 11-17-12, 02:21 AM
  #164
SPhoto
SPhoto's Avatar
I forgot to post, but this was yesterday...I finally received my parts for timing belt/water pump, and tune up job.
Old 12-01-12, 02:27 PM
  #165
RA40
RA40's Avatar
Last night's pick-up. Local Toyota dealer sent out $3.99/quart coupon. I couldn't get to that dealer but the other one did a price match. One of the upcoming weekends I'll do the partial drain. As well, the Toyota dealer sold the crush washers at $2.30 not the $6.95 one Lexus dealer nailed me for.
Quick Reply: What did you do to your LS400 today?
