easy exit seat movement does not move
Old 12-17-12, 04:37 PM
lynhnn
lynhnn's Avatar
Default easy exit seat movement does not move
'13 model.
I checked the vehicle customization to have the setting on but I noticed that the driver seat has stop moving assisting easy exit feature. The steering wheel is tilting however.
Should I check with the dealer?
Old 12-17-12, 06:47 PM
LexRexBlue
LexRexBlue's Avatar
Make sure you have designated how far you want the seat to go back.
Old 12-17-12, 11:08 PM
lynhnn
lynhnn's Avatar
I tried setting it to "off" then "partial" then "full" but nothing seems to moving. It was moving for the first month or so ...
Old 12-18-12, 03:04 AM
corradoMR2
The pursuit of F
corradoMR2's Avatar
Can you move the seat with the power seat switch or with one of the Memory seat buttons? If the seat moves, might be a long shot, but try resetting/saving the Memory seat at a new position. Then turn off the car and see if the seat moves back.
If it still doesn't work, I'd have it checked out at Lexus. Keep us posted - curious since I personally never had this issue with all the Lexus cars I owned and don't believe to have seen this issue posted prior ...
Old 12-18-12, 03:35 AM
kitlz
No, I don't play soccer!
kitlz's Avatar
I had this happen recently. Can't remember exactly what I did but it was a combination of moving the seat back and forward, then turning the seat exit feature off and on. It seemed to reset itself the next time I drove the RX. I already had the seat position in memory so I just needed to press the button to return it to what I like.
Old 07-19-13, 07:05 PM
jmolinario
jmolinario's Avatar
Just notice the same thing with my new 2013 ES350. Worked fine for a few weeks then stopped. I too have done all of the things mentioned in the thread, but no luck. Will be bringing that up when I go in for my 5k checkup.
Old 07-20-13, 04:28 AM
satnav
satnav's Avatar
I think by your wording it used to move back, and has stopped. But have you checked #18 of the link below? Maybe it was changed below by accident or memory leak. My audi used to forget MMI settings before I realized or the car warned of bad battery. Though you have new car so that probably isn't it.
http://www.lexus.com/pdf/service/RX_with_nav_LPS.pdf
Old 07-20-13, 06:29 PM
jmolinario
jmolinario's Avatar
Thanks satvav but ... been there, done that... no luck. will be bringing it by the dealer tomorrow as I will be near by... will post results.
elibutton (12-17-20)
Old 11-19-13, 10:34 AM
lynhnn
lynhnn's Avatar
Ok. I accidentally found out how to make the easy exit seat works again by lowering the seat a bit. I had the seat at its highest point and the easy exit does not work when the seat in that position.
I use the seat height adjust power button to lower it a bit. Then it starts to work...
Should I bring it back to dealer and get it fixed? Or is it working by design ?
Old 11-19-13, 03:50 PM
RickC5
RickC5's Avatar
I also used the customization feature on our 2010 to turn this on, but nothing--nada--zip. Was hoping for the wheel to tilt up, as I already have the seat all the way back.
Yet another disappointment. WTF?
nuraman00
ES - 6th Gen (2013-2018)
02-14-17 07:04 PM
2SAVVY
RC - 1st Gen (2015-present)
05-14-15 05:24 PM
Chris8152
RC F (2015-present)
03-06-15 03:43 PM
UnSub
10-10-11 05:57 AM
Quick Reply: easy exit seat movement does not move
