Red light with key logo blinking on dash
Old 12-22-12, 07:34 AM
blustoneIS
blustoneIS's Avatar
Default Red light with key logo blinking on dash
Hi fellow GX owners, my 08 has this blinking red light with key logo on my dash, when I lock it through the key, it stays on and does not blink.
No problem with starting, steering wheel, and keys has new batteries.
Please give me some inputs before I take it to the dealer.
Thanks! Much appreciated!
Mark
Old 12-22-12, 10:01 AM
ALAN553
ALAN553's Avatar
Have to double check, let's you know alarm is set, if you lock with key, not sure, but maybe alarm does not set.
Old 12-25-12, 09:52 AM
BODIK
BODIK's Avatar
Mark
Your immobilizer was flashed and it is still in a programming mode. To close it just turn the key on/off quickly for about 10 times until the light stop blinking. Just make sure to insert each key you have in the ignition for few seconds. The one with the gray head(valet key) must be last. If you have any questions just PM me.
Old 12-27-12, 08:39 AM
mann777
mann777's Avatar
Bodik...it is 10 Seconds on the wait period ( i am sure that's a typo).
Blustone...check the Owners Manual, it has the method done step by step.
Old 02-23-17, 11:41 AM
mstrsltr
mstrsltr's Avatar
TO CLARIFY, since no one likes to explain things CLEARLY on this site:
If the little red car with the key on it (aka security indicator) is flashing even AFTER you start the vehicle and stays on while driving, that means your vehicle is still in "programming mode" for keys.
To exit the vehicle from programming mode (i.e. stop it from flashing), you must:
Insert a recognized key. Rotate the key from the "off" to "on" position FIVE (5) times within TEN (10) seconds. The security indicator light (lil red car) should turn off after last turn.
Go ahead and start 'er up... the red light should not longer be blinking.
Old 10-07-18, 11:16 AM
sspc
sspc's Avatar
Thanks for this clear explanation. But what if you have a keyless entry? I have a button to start my car, don't need to inset a key
Old 10-08-18, 04:38 PM
chiph9
chiph9's Avatar
The people that installed your remote start likely taped/zip-tied a key module near the ignition switch so that it was in range of the immobilizer receiver.
Chip H.
Old 10-08-18, 06:25 PM
sspc
sspc's Avatar
That doesn't tell me how I can turn it off.
Old 10-09-18, 04:23 PM
chiph9
chiph9's Avatar
Contact the people that installed it.
Chip H.
Old 02-13-19, 10:00 AM
lexus4490
lexus4490's Avatar
Hey I had same blinking light issue 3 days ago - i did not bother- i drove everyday- yesterday it will not start- and steering wheel is locked....I red in forum and tried all tricks.... to unlock it but no success...key rotates all the way to start position but car doesnot start....nor do i get lights on dashboard...fyi its 2001 LX 470 and .battery is new .any helpful tips would be appreciated...
Old 02-13-19, 01:31 PM
ALAN553
ALAN553's Avatar
Ya got the wrong message board...GX 470
EddieSuxel
03-17-17 01:01 PM
PrisyCrisy
RX - 1st Gen (1999-2003)
30
07-28-16 05:52 PM
01_IS_4U
01-17-11 08:55 AM
jiboom
02-08-10 03:42 PM
psw
03-27-06 10:51 AM
Quick Reply: Red light with key logo blinking on dash
