Old 12-12-14, 03:42 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Print Wikipost
1996 Lexus ES300 Power Steering Fluid Change!
Old 01-13-13, 12:55 AM
Trahald
Trahald's Avatar
Default 1996 Lexus ES300 Power Steering Fluid Change!
Hi guys,
My power steering fluid level is low and I want to add some ATF to it. Problem is I don't know what kind of fluid and brand in it right now. If I buy Mobil 1 Synthetic ATF and add to current fluid, is there going to be any problem?
Thanks!
Old 01-13-13, 04:45 AM
Lexmex
Lexmex's Avatar
No issue whatsoever.
Old 01-13-13, 02:17 PM
Trahald
Trahald's Avatar
Ok, thanks.
Also I have one more question about coolant! I poured pure coolant to my car without diluting. I forgot to check the bottle. It says dilute with water. Can I add little water right now or it is going to be fine?
Old 01-13-13, 05:51 PM
Hayk
Hayk's Avatar
What kind of coolant did you add? And what kind did you have in the car?
Adding pure coolant is fine, as long as it's not a lot.
Old 01-13-13, 05:58 PM
Trahald
Trahald's Avatar
I asked to mechanic and he checked reservoir and gave me a Peak brand, green color one. I filled to top(full line) with pure coolant because it was almost empty.
Old 01-13-13, 07:18 PM
Hayk
Hayk's Avatar
I would recommend sticking with the Toyota brand coolant, it's a Red color. There is also a pink version that is already pre-mixed, it's for cars 2000 and above. The red coolant costs about the same as Prestone or any other brand, and I even found it at CarQuest (an auto parts store).
Old 01-13-13, 08:16 PM
Trahald
Trahald's Avatar
So, after green color coolant, isn't red coolant going to make any problem?
Old 01-13-13, 08:29 PM
Received 2,712 Likes on 2,297 Posts
They are compatible. Ideally you should have all the green removed, but some Toyota red is better than none.
Old 01-13-13, 09:41 PM
Hayk
Hayk's Avatar
Make sure you don't put regular water into the engine. It has to be distilled(pure). Plain tap water has minerals in it that can cause all sorts of nasty deposits.
Old 01-13-13, 11:03 PM
Trahald
Trahald's Avatar
Thanks guys!
Old 09-14-13, 09:07 AM
swhockey98
swhockey98's Avatar
Hi guys,
Thanks!
I know this thread is a little old and you may have already replaced the PSF, but I followed this tutorial yesterday and didn't have any problems. I also used Mobil 1 ATF.
Old 08-09-14, 10:53 PM
DexterG
DexterG's Avatar
Thanks..New to this site.. REALLY helpful.
Nauticalx
Hybrid Technology
16
11-07-22 09:14 PM
Stemmer
RX - 1st Gen (1999-2003)
11-04-12 04:35 AM
scottinky
22
02-04-11 01:11 PM
ToyotaLexus
02-12-09 10:05 AM
sneakyazn
05-30-08 04:04 AM
Quick Reply: 1996 Lexus ES300 Power Steering Fluid Change!
