What did you do to your GS today?
Old 04-02-13, 09:10 PM
  #46
socal72
socal72's Avatar
Originally Posted by RCFC89
New tails and coils...................
Very nice!!
Old 04-03-13, 08:54 AM
  #47
ThomasGS4
ThomasGS4's Avatar
Purchased an expensive part.
Old 04-03-13, 07:38 PM
  #48
Riksgs808
Riksgs808's Avatar
Today I tined the windshield of my gs with clear ceramic tint. It has a little bit of a blue tint to it. Keeps out heat and UV rays.
Old 04-04-13, 10:32 AM
  #49
JLAWS
JLAWS's Avatar
Continued the restoration of my 99 GS400 by swapping out a weak belt tensioner, Transmission Mount, that I did myself and motor mount which I paid a friend to do.
Holy cow what a huge difference in refinement !!!! Prior to replacing the parts the car ran very well. Some slight vibration at idle as if I needed a tune up but nothing to be concered about. I did have the delayed acceleration issue on a few occassions when I punched it, but I thought that was normal.
After the fix the car accelerates more much smoother and no longer has the rough downshift into a lower gears when I punch it (Like a neutral rev then drop into drive). ZERO vibration at Idle and it feels like it has more powa!
I know this has been said before, If you have over 100K miles just change out your motor and transmission mount. I used oem ones from Sewell Lexus. The motor mounts appeared to look OK but when they were out I could easily split them in half.
QLex300 (12-19-21)
Old 04-04-13, 01:22 PM
  #50
Jojo68
Jojo68's Avatar
Originally Posted by ThomasGS4
Hello,
One question : what are the size of your tyres on this wheels ? Thank for your reply.
Joseph, french driver of GS 300 gen 2.
Old 04-04-13, 01:40 PM
  #51
ThomasGS4
ThomasGS4's Avatar
Originally Posted by Jojo68
Hello,
These tires are 245/40/18
Old 04-04-13, 02:50 PM
  #52
mofoD
mofoD's Avatar
$22 shipped
Old 04-04-13, 03:21 PM
  #53
SC2JZ300
SC2JZ300's Avatar
Pick this up to replace my beat up one.
Old 04-04-13, 03:40 PM
  #54
DosyBoy
DosyBoy's Avatar
New ball joints
New tie rods
New motor mounts
Installed Monday, woohoooo!!!
Old 04-04-13, 05:11 PM
  #55
1UGLYGS
1UGLYGS's Avatar
well this week i...
did lower ball joints and shaved the rear fenders, Tomorrow rolling the fronts.
Old 04-04-13, 06:21 PM
  #56
tiger4life
tiger4life's Avatar
Not exactly today, two days ago. Installed the bootleg ssr center caps I made since werfen caps don't fit my wheels
SynDragon (01-31-22)
Old 04-04-13, 06:48 PM
  #57
BrokeGs4
BrokeGs4's Avatar
I plastidiped my 98-00 Grill
Old 04-04-13, 07:59 PM
  #58
ForeignVee
ForeignVee's Avatar
Oil Change
Trans drain & fill
Driver Side front strut mount
QLex300 (12-19-21)
Old 04-05-13, 08:01 AM
  #59
Jojo68
Jojo68's Avatar
Thank's for this information........and no problem with this size ( tires touching somewhere,even if you drive on a bump) ?
I want to put 18" wheels on my car, but I don't know for the tires ( 225/45R18 or 245/40R18) ??
Enjoy to read you,
Regards, Joseph.
Old 04-05-13, 08:34 AM
  #60
Longchampe
Longchampe's Avatar
New Timing belt, water pump, front crank and cam seals, oil change. Also polished my headlights with the 3m kit, they look much better but not perfect.
Quick Reply: What did you do to your GS today?
