ES300 02 - emergency trunk release latch
Old 04-28-13, 07:51 PM
moilexus
moilexus's Avatar
Default ES300 02 - emergency trunk release latch
Hi guys.
Today I decided to replace rusty license plate bolts.
So I removed the head from one bolt , and the same happened with the second bolt.
I tried Grabit Damaged Screw Remover and it didn't work. Now the only way to remove those two parts of the two bolts is to remove cover from the trunk.
I poped all the black clips,
but cannot remove emergency trunk release latch. I poped the upper part of the latch.
How do I remove the bottom part of this latch from the trunk?
Old 04-28-13, 08:58 PM
msekanha
msekanha's Avatar
it's actually pretty easy to remove.
the face plate of the handle pops right off,
and then you squeeze the clip that holds the handle on, then VOILA
Old 04-28-13, 09:48 PM
moilexus
moilexus's Avatar
Yeah
There are 4 clips which hold that part (and 2 additional just sitting there and doing nothing).
How do you squeeze them all at the same time?
I tried to pry them with wooden matches - didn't work.
Old 04-29-13, 07:07 PM
moilexus
moilexus's Avatar
How do I squeeze all 4 big pins at the same time?
Old 04-30-13, 11:11 AM
msekanha
msekanha's Avatar
Ahhh, I see what you're saying now.
I remember now that was a PITA to remove.
Honestly, I pulled and held on the handle while
Depressing those with. A pair of needlenose clips and it Eventually just popped off.
You know what I meAn?
Old 09-29-18, 08:40 PM
JesseTread
JesseTread's Avatar
I deleted message bc I was incorrect
Old 03-07-23, 04:02 PM
Gustavo87
4th Gear
Gustavo87's Avatar
RESOLVED
Originally Posted by moilexus
Hi guys.
So I ran into this problem as well. Figured it out.
You don’t bother trying to push all the pins in.
1. First you take a flat head and split the handle in 2.
2. Take pliers and literally just pull it off. It will come off.
(Not needle nose pliers).
That’s it. It pulls off. Scary but it does just come off.
daredeil95
07-23-18 08:15 PM
jkayca
ES - 5th Gen (2007-2012)
10-19-17 10:31 AM
Ronstitt
04-04-16 05:25 PM
Fatnslow
07-09-15 08:34 PM
chi123
06-16-11 07:26 PM
Quick Reply: ES300 02 - emergency trunk release latch
