When jacked up, should my wheel spin freely?
Old 05-01-13, 03:43 PM
Studiogeek
Studiogeek's Avatar
Question When jacked up, should my wheel spin freely?
Greetings,
While jacked up to swap wheels get an alignment. I noticed when I tried to spin a wheel, it was hard to turn. Not two hands hard but it would NOT continue to move at all when I let go. No freewheel or spin was possible. This was a front wheel but I may have tried it on a rear as well.
i thought this could be a cause for my horrible gas mileage.
Should my wheels be able to spin freely at all after i let go?
Old 05-01-13, 04:39 PM
chiken
chiken's Avatar
They should spin fairly free. At least one or two rotations before stopping, maybe more depending on how hard you spin it. It could be a caliper locking up. Jack up the whole front end and compare both front wheels for resistance. Also check brake pad wear from side to side. It will kill your gas mileage.
Old 05-01-13, 07:39 PM
Biddles
Biddles's Avatar
Damn calipers... I got mine off rock auto, the loaded Centric ones. Good stuff.
Old 05-05-13, 06:29 PM
durps
durps's Avatar
If its a caliper thats locking do you replace the caliper or do you just push the brake piston out and install again?
Old 05-06-13, 03:27 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
I'm wondering as well...
Old 05-06-13, 03:39 PM
mattjk
mattjk's Avatar
there should be some bearing drag when you spin the wheels.1 to 2 rotations at most when spun by hand as chiken said.
If your calipers are dragging badly, you can hear the pads scraping against the rotor, however, pads are designed to lightly drag on the rotors at all times. This is to keep the rotor surface clear of water when driving in the rain. There are flat springs that do this.
Old 05-06-13, 03:59 PM
chiken
chiken's Avatar
You have to replace the caliper. Typically if its stuck or seized you won't be able to compress the pistons.
Old 05-07-13, 07:31 AM
Dougspeed
Dougspeed's Avatar
Another common source of stuck calipers are seized caliper bolts/pins, which you will want to check for before replacing the whole assembly. The rubber boot that keeps the grease packing on the sliding pins deteriorates over time allowing the grease to dry out and the pins to start rusting which prevents the caliper from sliding freely. It's a cheap fix if that is the problem. Just remove the pins and if they're not bent, clean them off of all the rust, regrease, replace the rubber boots, and reinstall them.
Old 05-07-13, 08:46 AM
Studiogeek
Studiogeek's Avatar
Good to know!
Thanks!
Old 05-07-13, 09:54 AM
Tabaka
Tabaka's Avatar
Rubber boots around the pins? You've lost me. I don't remember any rubber boots around the LS brake pins. There is a rubber boot around the drain flush bolt.
Old 05-07-13, 10:02 AM
Blkexcoupe
Blkexcoupe's Avatar
He's referring to the rubber boot on the sliding pins for a floating caliper that comes stock on the SC3/4. LS400 calipers are monoblock, so their design doesn't require sliding pins for the caliper to work.
Old 05-07-13, 11:32 AM
Dougspeed
Dougspeed's Avatar
That is correct, here's an image to show what I was referring to, you can see one of the boots at the top right side of this stock SC3/400 caliper in the pic below.
Old 05-07-13, 01:39 PM
Tabaka
Tabaka's Avatar
Ok, gottchya. I've had some problems with my LS brakes and thought I missed a step.
Old 05-07-13, 01:54 PM
Candela
Candela's Avatar
Those boots can be purchased at auto parts stores right? Hardware kit?
peasodos
04-10-19 07:51 PM
CleanCL
Suspension and Brakes
10-04-10 03:04 PM
detailersdomain
Automotive Care & Detailing
14
05-11-09 10:58 PM
TGRich
Wheels, Tires & Brakes Forum
16
03-16-04 09:50 PM
Quick Reply: When jacked up, should my wheel spin freely?
