6766/1jz what size oil feed?
Old 05-08-13, 11:56 PM
emoFTW
emoFTW's Avatar
Default 6766/1jz what size oil feed?
What size oil feed are you guys running on a 6766? I'm running it on a 1jz if that matters. I've heard mixed reviews between -3 and -4.
Also what size oil return? -10?
Thanks.
Old 05-09-13, 08:07 PM
Vrank
Vrank's Avatar
Personally I would email precision and ask them specifically what to use if this turbo is new and under warranty. Then save it, so if you have a failure you can have a record of utilizing their recommendations. There have been issues with this in the past and precision can be some **** about stuff
Old 05-09-13, 08:11 PM
Vrank
Vrank's Avatar
Also, what really makes a difference is the cartridge. Is it ball bearing or journal?
Industry standard is -4 for journal, -3 for ball bearing. You're about to have a lot of people telling you restrictor this restrictor that with -4, like in a lot of the holset threads around where the people don't really have first hand experience. This place is bad about that. Another reason I suggest contacting the manufacturer aside from covering your ***.
Old 05-09-13, 10:04 PM
emoFTW
emoFTW's Avatar
It's a journal bearing, and yes brand new.
You speak the truth man! I'll be sure to give them a call, but I was just making this thread to see what people were running with this turbo. Thanks for your input!
Old 05-10-13, 05:06 AM
99SC42
gte & na-t
99SC42's Avatar
I ran a -4an for feed and -10an return on my 6765 billet.
You can run -12an return if you want , shouldn't run anything less than -10an for return.
GL
soarer25gt
SC400 / 300 Classifieds
02-05-13 10:40 PM
Parker Gen
24
09-11-12 11:09 AM
1JZPWRD
38
03-03-12 09:38 AM
dandd2
08-31-10 10:31 AM
phil2235nt
06-30-08 07:50 PM
Quick Reply: 6766/1jz what size oil feed?
