Ticking Noise
Old 05-09-13, 06:45 PM
obrian401
obrian401's Avatar
Default Ticking Noise
My 2001 Lexus es300 is making a ticking noise that's coming from under the car as i drive or when idling high. The car also have low RPM's when the AC is on. what could be causing the ticking noise, and low RPM?
Old 05-12-13, 12:41 PM
Idreamido
Idreamido's Avatar
Hi, I have been experiencing the same tick tick sound when the car is stopped after driving...mine is 2005 ES330
Old 05-13-13, 06:35 AM
ViPeRs103
ViPeRs103's Avatar
obrian401 I agree 100% as I have the same situation occurring on my 01 ES. It almost sounds like the issue is coming from the charcoal canister assembly!!
Old 05-13-13, 06:46 AM
PFB
PFB's Avatar
I'm not cllear if you are hearing the ticking sound while the engine is running, or right after it stopped. But if you hear it after it stopped, than its just your exhaust system cooling down, and the metal is making those sounds while it's cooling. If that's the case than is perfectly normal
Phil
Old 05-13-13, 12:22 PM
Idreamido
Idreamido's Avatar
In my case (its 2005 ES330) it happens right after car is stopped...the sound is quite audible...i bought this car couple days ago and was little concerned.
Phil
Old 05-13-13, 04:04 PM
ViPeRs103
ViPeRs103's Avatar
Phil
The sound is heard when vehicle is running at idle state
Old 05-13-13, 06:22 PM
Idreamido
Idreamido's Avatar
This is what it sounds like when the car is parked after driving...can someone please suggest whats going on.
File Type: zip
Old 05-13-13, 07:26 PM
imherenow
imherenow's Avatar
hmm sounds like you might need to adjust the valves. if so then will have to remove the gasket cover
Old 05-13-13, 09:05 PM
Received 2,712 Likes on 2,297 Posts
Perfectly normal, my car does the exact same thing. In fact I think I can even hear a bit of that ticking noise when my engine is idling, it might have something to do with the fact that the exhaust pipe joints have bolts with springs on them but not sure it could just be the metal expanding/contracting.
Old 04-19-18, 09:04 PM
nparthi
nparthi's Avatar
I am hearing the same sound on my 2005 ES330 right after the car is stopped. Is this normal? Do you remember what you did to fix this?
(I understand you had posted this 5 years ago)
Griztko
LX - 3rd Gen (2008-2021)
06-04-18 04:48 PM
ghoffner
RC F (2015-present)
12-03-15 12:47 PM
jtwags
07-06-13 11:20 AM
LexusISF23
IS F (2008-2014)
02-19-13 06:01 AM
joker
22
07-05-06 02:54 PM
Quick Reply: Ticking Noise
