DIY: sport ebrake pedal
Old 05-10-13, 11:01 AM
euroimage
euroimage's Avatar
Smile DIY: sport ebrake pedal
So many of have seen this,
http://www.nigel-jdmparts.com/pedal-for-foot-brake?
In the description it says modifications needed for install.
So after I ordered this and received it, I found that it is merely a sport clutch pedal.
After removing the stock ebrake pedal it was clear to see that it wouldn't be a matter of trimming the metal bracket to make it fit.
Options :
Put screws thru your nice new pedal ( would look tacky)
Glue the pedal to the base ( probably wont hold up for long)
Fab a backing plate
Obvious choice that takes the most effort but has the best long term affects is the route I chose.
Materials:
1/8" thick aluminum flat bar (I had scrap aluminum so I did not measure width)
Angle grinder with flap wheel
Vice
Pedal
Screw/nut with a semi flat head
Drill with appropriate sized bit (I used a step bit to recess the head of the screw)
Saw capable of cutting aluminum bar
Pliers
Screwdriver
File
I did not take pictures of every step, just the important ones.
First take a piece of paper and make a rough template of the size you will need to cut the aluminum to
Then cut aluminum to rough length
Now take your template and use a sharpie to draw it on the aluminum.
Place aluminum in your vice and grind down the sides to the lines drawn with the sharpie.
This part is all trail and error, grind, check, grind, check.
Eventually you will get it looking like a pedal.i made it a tad smaller to make it easier to install the pedal over the backing once it was in the car.
After I was content with the size and felt it was small enough to get in the pedal, but not too small not to hold, I drilled a hole in the center of the plate.
I then placed this new backing plate in the vice and used some pliars to bend the aluminum slightly. Just enough to match the curve of the pedal cover
You will end up with something like this
Be sure to file the edges so there is no rough edges to rip the rubber on when installing
Then take your nice new backing plate and bolt it to the metal arm of the ebrake (there is already a hole there) try your best to align the bottom of the pedal so it looks even with your brake pedal
And you have this:
Then install the pedal cover just as you would with the brake pedal, sliding the plate into the lip of the rubber. Takes some patience to make sure it's all properly in there (which is why I made mine a hair smaller)
Stand back and enjoy your new ebrake pedal that now matches the rest of your pedals!
This may not be for everyone due to the fabrication, but it only took me about 20 mins from start to finish, and I will not have to worry about the pedal getting loose or anything since it as OEM of an install as possible. *installed pic I did not have 100% on, so it is slightly not lined up in that photo*
Any questions let me know!
5gears-IS (05-03-17)
Old 05-10-13, 11:09 AM
Sffd103
Fire Slayer
Sffd103's Avatar
noce job and it looks good! Now vacuum your floor mats!! haha
Old 05-10-13, 11:17 AM
euroimage
euroimage's Avatar
Thanks! Haha Sundays are detail days
Old 05-10-13, 11:32 AM
B16da9
B16da9's Avatar
this thread makes me wish I had taken the sports pedal of my 6MT before the insurance took it.
Old 05-10-13, 04:27 PM
Jake
Jake's Avatar
I have the same e-break cover. Instead I drilled a black screw (to match the screws on the dead foot petal) in the center of one of the black rubber dots and then put a washer and nut behind it to hold it down.
Old 05-10-13, 09:49 PM
jleeIS
jleeIS's Avatar
Looks great! Might be my next mod, thanks for the write up.
Old 11-09-16, 09:56 PM
10lexISR6
10lexISR6's Avatar
Such good info! Im subscribed
Old 11-10-16, 06:16 AM
strikeraj
strikeraj's Avatar
just wondering... if going through the trouble of fabing an aluminum backplate.... can we just make the pedal itself?
Old 05-11-17, 12:45 AM
pchang619
pchang619's Avatar
Has anyone made this? I am not handle at all but if anyone selling one. I would love to buy it from them. I already got the pedal clutch.
Old 05-11-17, 07:15 AM
10lexISR6
10lexISR6's Avatar
Just buy an extra brake/clutch pedal, drill a hole through one of the black rubber pads and there is a stock hole behind the ebrake pedal. It lines up almost pefectly. Zero issues and looks legit. Although the back plate way is the ultimate clean look.
Old 05-11-17, 08:48 AM
mandyfig
mandyfig's Avatar
Where can you buy just the brake pedal? Links? I would love to replace mine.
Thanks.
Old 05-11-17, 12:11 PM
jr4div2
jr4div2's Avatar
Thanks.
http://www.ebay.com/itm/like/182391012952?vectorid=229466&lgeo=1&item=182391012952&rmvSB=true
Singles on amazon
Amazon Amazon
Old 05-13-17, 05:33 AM
mandyfig
mandyfig's Avatar
Sorry, I meant the parking brake pedal. To complete my Fsport set.
Old 05-13-17, 09:22 AM
Soledad
Soledad's Avatar
Thanks for posting this. I think I'm going to give it a try.
http://www.ebay.com/itm/TOYOTA-LEXUS-OEM-GENUINE-MANUAL-TRANS-ALUMINUM-CLUTCH-BRAKE-PEDAL-31321-53010-/172335312106
https://www.amazon.com/Toyota-31321-53010-Toyoya-PAD-PEDAL/dp/B018INMFPS
Old 05-13-17, 11:41 AM
pchang619
pchang619's Avatar
If anyone already made one. I would like to buy it. Please let me know! This will surely complete my pedal look.
gulshan
NX - 1st Gen (2015-2021)
06-17-19 06:07 PM
02-28-17 10:28 AM
teracon
04-16-12 07:45 AM
Dj_AmtraX
03-24-07 01:09 PM
tqlla3k
05-06-06 12:53 PM
Quick Reply: DIY: sport ebrake pedal
