Sway bar kit
Old 06-20-13, 08:25 AM
RamAirRckt
RamAirRckt's Avatar
Oh, and if the lever on these is shorter than stock, then it will increase the overall effectiveness of the bar. Thickness is not the only attribute.
My 80 Turbo T/A has a Rancho Challenger GTIII front bar, only 1.25", but it is adjustable and it is 900 lb/in deflection at max. This is crazy stiff (yes, it DID rip the bar/frame bushings out of the FRAME), to compare, HO Racing has a 1.5" bar and it is only 550 lb/in deflection. My car is thinner, but yet is much stiffer.
I am here to tell you, there is such thing as too stiff. I love the stiff bars I had, but they don't come without baggage. They had heim joints for link kits and they would breat catastrophically at times, which could be dangerous, for me, never in a hard handling condition, usually over a pot hole.
Old 06-25-13, 08:56 AM
RamAirRckt
RamAirRckt's Avatar
Got my bars in, will post picts soon.
They weren't packaged the best, they were wrapped in plastic, but not really anchored down in the box, the front did poke a hole in the box, didn't seem to hurt it. The rear bar has a small chip of paint off front hitting the other bar. Else initially seems ok.
Old 06-25-13, 09:15 AM
GSdarksol
GSdarksol's Avatar
^Interested to see pics and feedback.
Old 06-25-13, 10:29 AM
RamAirRckt
RamAirRckt's Avatar
They are fairly light, nothing like a solid bar for my T/A or my Fleetwood (1.25" solid and 1 1/8" solid respectively).
They come with bushings and brackets.
No complaints so far other than packaging is poor.
Attached Thumbnails Sway bar kit-img_00000004.jpg   Sway bar kit-img_00000005.jpg   Sway bar kit-img_00000006.jpg   Sway bar kit-img_00000007.jpg   Sway bar kit-img_00000008.jpg
Old 06-25-13, 10:38 AM
pdxgs
pdxgs's Avatar
Not bad, are they rubber or poly bushings?
Old 06-25-13, 10:42 AM
RamAirRckt
RamAirRckt's Avatar
I think rubber, I hardly gave them notice before I left home this morning, but I think rubber, black, they didn't stand out like Polyurethane.
In some cases maybe good, Poly's can be squeaky and can break if abused. All depends on the design.
Old 06-25-13, 01:59 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Thanks for the pics.. They sure are beefy.. your thoughts on handling when installed... i probably would go with poly bushings just because The TRD and Daizen use them.. I guess it would "complete" the package..
Old 06-25-13, 02:14 PM
RamAirRckt
RamAirRckt's Avatar
I guess after seeing my Rancho GTIII bar and the HO Racing bars for the G Body Cutlass and Impala SS, these are TINY... The HO Racing rear bar is 1.5 solid.....
Here is a 1.375" rear bar...
http://www.bmrsuspension.com/siteart...B006_large.jpg
http://www.bmrsuspension.com/index.c...s&productid=70
Remember too, the thickness of the bar is one thing, but the lever is another, a shorter lever really makes a big difference in the stiffness.
Old 06-25-13, 03:27 PM
AVSRacing
AVSRacing's Avatar
Is it just me or the actual welds look pretty poor and weak on the bars. The rear bar weld doesn't even look straight
Old 06-25-13, 03:38 PM
RamAirRckt
RamAirRckt's Avatar
I'll be able to look closer when I get home, it isn't in a good place to set it straight right now. I'll take close ups of the welds.
Old 06-26-13, 10:56 PM
RamAirRckt
RamAirRckt's Avatar
Got the old bar off, can't get new one on due to some broken bolts.
Relatively easy, but here is a run down on how.
Tools needed:
10mm socket
12mm wrench
12mm socket
14mm wrench
Allen wrench to fit link kit fitting
3" and 12" extensions for the ratchets.
1. Remove covers over control arm. (I broke bolts here too)
2. Spray PB Blaster on bolt coming out to the rear of the arm, in line with the link to the bar.
3. Remove 12mm bolt that goes thru the arm and on pass side, connects to the suspension height sensor.
4. Spray PB Blaster on Sway Bar to Frame Bolts. Let sit for a bit.
5. Remove Bar to Frame bolts (12mm with 12" extension)
6. Remove bar from car.
7. Remove link kit from old bar (unless you have new ones), this needs 14mm wrench and allen wrench to fit inside bolt end to hold it free. I used vice grips due to not seeing the allen wrench hole in the bolt end. Pain in the caboose that way. It is very tight.
8. Install bushings on new bar, note which way is proper, flat edge UP.
9. Install link kit on new bar. Note the link kit is outside the ends of the bar.
10. Fish bar in car.
11. Bolt bar to frame
12. Bolt link kit back into control arms.
Fit new bushings on the bar, I used some Amsoil MP to let it slide on easily. The supplied bushings are right size, but are a bit different type, recommend get some better bushings if you can. The OEM design is proper for the bracket, the supplied bushing is for a flat bar bracket, look at the front bracket in the picture below. OEM brackets are different and require a different bushing.
Attached Thumbnails Sway bar kit-img_00000022.jpg   Sway bar kit-img_00000023.jpg   Sway bar kit-img_00000024.jpg   Sway bar kit-img_00000025.jpg
Old 06-27-13, 12:20 AM
tmf2004
tmf2004's Avatar
What a huge difference in thickness.... Can't wait for your review... Also please post up what bushings we will need for the front... Your right the ones pictured don't fit correctly... Thanks
Old 06-27-13, 06:13 AM
RamAirRckt
RamAirRckt's Avatar
I am putting rear on first, my natural inclination, as OEM typically sets up the car to being a tendency to understeer, this will either make it much more neutral or oversteer. I ran my 85 Cutlass with factory small front bar and 442 rear bar for years, was nice and balanced, but overall was more enjoyable to drive once I got the 442 front bar in, but lost the neutrality in handling. Just have to add power to make it oversteer then....
I just ordered some cobalt drill bits to drill out the bolts that broke off. Frustrating.... But not unexpected...
I guess based on what I see so far, for the price, it is impossible to beat. Bars shouldn't be very expensive, they are bars.....nothing more than that with a couple bends and ends welded on.
Old 06-29-13, 10:53 PM
RamAirRckt
RamAirRckt's Avatar
Rear bar on, will drive tomorrow....
Old 06-30-13, 10:29 AM
perry05g35
perry05g35's Avatar
New day and it's time for an update!
Quick Reply: Sway bar kit
