Size matters! - let's put a BIG oil filter on our LS!
Old 05-21-13, 05:18 PM
  #46
LScowboyLS
LScowboyLS's Avatar
Originally Posted by diamondave
I should cross reference that to a mobil 1 filter.
M1-301 I believe - it's a beast!
Old 05-21-13, 05:19 PM
  #47
diamondave
diamondave's Avatar
let me know how that test works on the ph8A. If so i will go even bigger. Will be doing an oil change this weekend
Old 05-23-13, 03:53 AM
  #48
LScowboyLS
LScowboyLS's Avatar
Dude! - I think you need to give her the full 7 inches!
go get yourself a 40 of Colt 45 to drink while you are installing this 40 oz!
and pick up some extra oil, you're gonna need it!
Old 05-23-13, 08:34 AM
  #49
diamondave
diamondave's Avatar
ok npow cross reference that to a mobil 1
Old 05-23-13, 08:35 AM
  #50
diamondave
diamondave's Avatar
and does it have the same pressure as stock?
Old 05-23-13, 08:38 AM
  #51
LScowboyLS
LScowboyLS's Avatar
yes, meets all of the stock specs, gasket size, thread size & pitch, pressure, bypass pressure, flow rate etc. but no Mobil 1 version of this King Kong
largest Mobil 1 filter is about half that size, M1-301
but on a serious note, I doubt the giant WIX filter will physically fit due to the sway bar or some similar suspension component
Old 05-23-13, 08:39 AM
  #52
diamondave
diamondave's Avatar
do you think king kong will have any clearance issues?
Old 05-25-13, 09:19 AM
  #53
diamondave
diamondave's Avatar
changing oil today. can you confirm that wix will fit?
Old 05-25-13, 09:26 AM
  #54
python
python's Avatar
caveat to those who follow advice given,u can ruin ur motor..putting a larger filter in will give u absolutely no advantage.
1348 vs 1773=15 micron compared to 32...you people need to realize the importance of engineering.
when is the last time u changed ur air filter...probably more important than an oil filter
Old 05-25-13, 11:17 AM
  #55
sha4000
sha4000's Avatar
This has been a pretty informative read so far from everyone involved so I hope this one can stay open.
Old 05-25-13, 12:10 PM
  #56
Dutchy
Dutchy's Avatar
I'm curious what Yamae thinks about the bigger oil-filter.
I only use oem filters, and change every year or 15.000km the engine-oil and filter. I don't see any problem with this.
Old 05-25-13, 12:28 PM
  #57
diamondave
diamondave's Avatar
I will be changing oil in a few hours and i am going with the wix 51773. Will report back with fitment and how it performs
Old 05-25-13, 01:56 PM
  #58
python
python's Avatar
ur putting in a filter that has a higher micron rating... over twice the size of particles will be allowed to flow through the motor..btw that 1773 is for big trucks and tractors. ..these engines have run well over 4-500,000 miles using the specified filters...why change? ..its ur car do as u please. I wont be using any fram filter with ext oci or removing my ecm to diag my car.
Old 05-26-13, 03:12 PM
  #59
diamondave
diamondave's Avatar
Well she couldn't handle all 7 inches. It's just too big! So i put a mobil 1 M1-301 on her and she works great! Also another added bonus is that the engine is running a bit cooler. Usually the temp gauge would be exactly horizontal during normal operation which would be between the 2 marks but now it is running at the lower mark. I would recommend anyone doing this. Also on an added note an oil change will be exactly 6.1 quarts with the M1-301 filter. More filter and more oil is nothing but added benefit! You could conceivably go 15k or more between oil changes with a high quality oil like Mobil 1 but i personally will change about every 8-10k. we could see an added 100-200k on engine life with this too! Less heat and better filtering and better oiling! I have done this in previous cars but never really realized the benefits! Thanks again LSCowboy! This rocks!
Old 05-26-13, 03:18 PM
  #60
Dutchy
Dutchy's Avatar
More oil has nothing to do with your coolant temperture, maby oil temperture goes down but is that better? Probaly the thermostat had his best time... Or the gauge is not working properly.
Quick Reply: Size matters! - let's put a BIG oil filter on our LS!
