2004 rx330 ticking noise in dash
Old 05-25-13, 09:16 PM
boo1678
boo1678's Avatar
Default 2004 rx330 ticking noise in dash
My rx330 occasionally has a ticking noise to the left side of the steering wheel in the dash. Will do it for an hour or so and then not do it again for 4 or 5 hours.
Any suggestions greatly appreciated
Old 05-26-13, 08:09 AM
Rainbird
Rainbird's Avatar
Possibly one of the servo motors or fuel injectors (see links below):
https://www.clublexus.com/forums/rx-...ch-advice.html
https://www.clublexus.com/forums/rx-...ing-noise.html
Old 06-21-13, 06:56 AM
LS430LX470
LS430LX470's Avatar
Have you figured out what that ticking noise is ???? I have the same issue with mine it got so bad it sounded almost like a rat or something in my dash trying to get out.... I was a little freaked out... turns out there is a little lever under the passengerside of the dash that must control the vent movement... and it was caught up so the motor kept ticking... with a little bit of grease it was all good./.
Old 06-24-13, 05:39 PM
mcftlf
mcftlf's Avatar
I had this same kind of ticking....it ended up being the little paddle that changes the direction of the air on the passenger side near the fire wall behind the gear shift console. It was stuck on my vehicle. It finally corrected itself.
2004 RX 330
Old 04-08-14, 08:03 AM
CLPETTY
CLPETTY's Avatar
I have a rx330 its having a clicking issue too behind the dash on the right hand side of the column... I have been unsuccessful on finding the cause.. Anyone run into this before?
Old 04-08-14, 08:46 AM
RX330inFL
RX330inFL's Avatar
Welcome to Club Lexus, CLPETTY.
More than likely, just as with this topic, it is one or more of the AC servos. You can search the forums here at CL on the topic and find a number of threads for the RX330, such as:
These are the parts:
http://lexus.sewellparts.com/accesso...2004/4620.html
Old 04-08-14, 09:52 AM
CLPETTY
CLPETTY's Avatar
[QUOTE=CLPETTY;8473933]I have a rx330 its having a clicking issue too behind the dash on the right hand side of the column... I have been unsuccessful on finding the cause.. Anyone run into this before it sounds like a relay clicking ....
smackfreek
05-27-21 01:21 PM
DB S600
10-22-10 03:50 PM
dwnsouth
08-21-07 05:54 PM
Treb
05-29-07 01:02 PM
GRAYM
RX - 1st Gen (1999-2003)
11-05-02 02:10 PM
Quick Reply: 2004 rx330 ticking noise in dash
