IS250 slow / difficult to start engine
Old 06-25-13, 01:42 AM
fatjoez
fatjoez's Avatar
Question IS250 slow / difficult to start engine
My lexus struggles to start the engine when I press start, everytime for past 2 days.
The only way the engine starts is if I press accelerator pedal while pressing start button.
Warm start seems to work okay.
Can you guys suggest possible causes?
Spark Plugs?
Battery?
Starter motor?
My Car has 128,000km. I bought it at 96,000km.
Only service items I have done is Engine OIL + Filter.
Don't know if previous owner has changed spark plugs etc
Old 06-25-13, 02:05 AM
Jaykobo
Jaykobo's Avatar
start cleaning the throttle body .... it happen mostly in all cars and a few think about throttle body....slow accelration.....low RPM.....hard to start specially in cold weather
second check the air mass sensor and IAC......maybe need cleaning or replace.....cos when you cranking engine mostly the mixture become rich and need air and it's the air mass sensor job.......that's why you need to press the pedel when you start engine......start cleaning first cos so you won't lose bucks
the new cars need throttle body cleaning every while depend on the place you live in.....my country is dusty and I clean it every 3 or 4 months
vid of how for all cars
so the important thing it not to push the throttle plate by eny thing....open the key only on don't let the engine crank and inside and around
to me I use
it's work but it's hard to start surging and smoke a lot ...need to keep the rpm on 2000 until it work smooth but will keep somking for 15 mins...but you get the result 100%
Forget to told you not to use this for cleaning the sensors........use electronic cleaner and there is a special cleaner for sensors I don't know it's name actully cos I never use it
Old 06-25-13, 12:01 PM
stanjohn12
stanjohn12's Avatar
It could also be that you used a high temperature oil than a low temperature one like 5W30 or 0W20 as relevant to your climatic conditions.
Old 06-25-13, 01:08 PM
mattsti10
mattsti10's Avatar
I would check the type of oil being used, then check the throttle body, then check the IACV. Are you noticing a high idle?
Old 06-25-13, 06:55 PM
fatjoez
fatjoez's Avatar
Last oil change 5000km
Castrol fully synthetic 5w30
cold start = 13degrees celsius.. not that cold
Idle is normal
Aftermarket Battery has some powder buildup around it
Car is 7 years old
Whats iac
Old 06-25-13, 07:01 PM
jdmSW20
jdmSW20's Avatar
Idle is normal
Car is 7 years old
Whats iac
idle air control valve
SJKNSW
02-14-19 09:18 PM
dbui
RX - 1st Gen (1999-2003)
15
12-16-15 07:54 AM
gpow
08-21-13 02:05 PM
fyuen
03-09-08 05:53 PM
gazi001
09-16-07 07:20 PM
Quick Reply: IS250 slow / difficult to start engine
