2005 es330 front and rear caliper toque spec's
Old 06-27-13, 02:31 PM
SGLexus
SGLexus's Avatar
Default 2005 es330 front and rear caliper toque spec's
Hey guys i was doing a brake job on my es and was wanting to make sure i had the right torque spec's for the rear caliper bracket and slide and also the front caliper bracket and slides
Thanks
Old 06-27-13, 03:02 PM
KLF
KLF's Avatar
Fronts: The bolts that go into the slide pins get 25 ft-lbs. The bolts for the caliper brackets get 79 ft-lbs.
Rears: The slide pin bolts get 25 ft-lbs. The bolts for the caliper brackets get 46 ft-lbs.
Old 06-27-13, 03:27 PM
SGLexus
SGLexus's Avatar
Alright thanks
Old 06-27-13, 04:36 PM
SGLexus
SGLexus's Avatar
Default 2005 Lexus ES330
Well while loosening the rear slide bolt and the Bolt snapped in side the hole and now we were so close and stumped. Really feeling bad. The caliper bracket bolt is stripped and don't know where to get the part .
Old 06-28-13, 09:04 AM
SGLexus
SGLexus's Avatar
Default Where could I get the rear caliper bolt?
Anyone have an idea of where I can get the rear caliper bolt?
Old 06-28-13, 12:09 PM
KLF
KLF's Avatar
Part #90119-10379
That is a special application hardened bolt, dealer only. List price is only $1.34.
Old 06-28-13, 01:04 PM
SGLexus
SGLexus's Avatar
hey thanks LKF! So does that mean only the dealer can install it? I need to get that small part of the bolt out that stuck in when it stripped tomorrow.
Old 06-28-13, 01:46 PM
KLF
KLF's Avatar
No just that I would only buy that from Toyota or Lexus. Not from a hardware store.
Posted from ClubLexus.com App for Android
Old 07-17-23, 11:39 PM
XSV
XSV's Avatar
thanks for the info doing a brake overhaul on my ES
jimsdrx200
02-03-16 02:40 PM
jiggawho
IS F (2008-2014)
03-20-15 08:43 PM
endlesslex
06-10-14 01:30 PM
JDKane527
Suspension and Brakes
10-01-12 01:47 PM
tuxlexus
RX - 1st Gen (1999-2003)
03-26-07 03:31 PM
Quick Reply: 2005 es330 front and rear caliper toque spec's
