Build Threads Details on Club Lexus SC owner vehicles
CatManD3W SC300 Ongoing Build...
Old 02-22-14, 01:45 PM
  #61
CatManD3W
CatManD3W's Avatar
Got the spoiler mounted today....92-95 lip spoiler...Thanks for the pics Steve
The workstation....Patiently awaiting for parts to arrive....so I can start rebuilding the engine
Old 02-22-14, 06:15 PM
  #62
lilSCsteve
lilSCsteve's Avatar
Spoiler looks good bro! After we talked, I think I'm going to build one side of my bench higher to put larger things underneath...good call! Keep the updates coming.
steve
Old 02-23-14, 09:25 AM
  #63
gerrb
gerrb's Avatar
Ryan - are you tearing the engine apart ? Or just replacing HG,oil & water pump...
Old 02-23-14, 09:48 AM
  #64
Justin2JZ
Justin2JZ's Avatar
Nice build man
Old 02-23-14, 11:15 AM
  #65
CatManD3W
CatManD3W's Avatar
Yes I am going to be replacing all of the above you mentioned(HG, Water Pump,Oil Pump, Valve seals, Rear main seal...etc) I have purchased the complete 2jzgte gasket kit....I also have a set of ARP head studs to install as well..
Old 02-23-14, 11:17 AM
  #66
CatManD3W
CatManD3W's Avatar
steve
Yes I made my workbench 38" high to accommodate more things underneath....its a little higher than standard but it makes it nice to work on as it is at arm level...
Old 02-23-14, 02:29 PM
  #67
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I made my work bench about the same height. Makes more sense to make room underneath and keep your back from hurting from looking down so much. Glad you liked my wrapping job on the studs. LOL
Old 02-23-14, 03:29 PM
  #68
CatManD3W
CatManD3W's Avatar
It makes it much easier....Funny part about my workbench....I measured the height of the engine stand when it is put together in the store and based the height of it to make sure I could fit it underneath when not in use....I Knew I was going to do the swap at some point so I was prepared!!!
Old 02-23-14, 03:34 PM
  #69
CatManD3W
CatManD3W's Avatar
Originally Posted by Justin2JZ
Nice build man
Thanks.........
Old 02-25-14, 09:56 AM
  #70
CatManD3W
CatManD3W's Avatar
Waiting for parts to get here....
Did manage to get the engine put on the engine stand.....Was a little surprised on how high it was
Also for those of you who are looking or wondering what bolts to use here are the specs M12x1.25x80 (12mm bolt size, thread pitch of 1.25 and length of 80mm)
I also picked up some washers to space it out...3 on each bolt worked perfect
Added a some extra support in the front as a precaution...The stand is rated for 1000lbs but I feel better with the 2x4 in the front
Old 02-27-14, 10:32 AM
  #71
Ali SC3
Ali SC3's Avatar
looking good, haha yeah I never trust those things either I have a jack stand under my crank pulley just in case someone decides to lean on it or run into it or something.
Old 02-27-14, 12:40 PM
  #72
CatManD3W
CatManD3W's Avatar
Wiring Harness Build Workbench...Merging Process has begun..i.e Dining Room Table
My lady is not to happy with this setup....lol
I also received my first parts order today...
Old 02-27-14, 01:27 PM
  #73
gerrb
gerrb's Avatar
oh shoot .. . I bet she is not happy.
Old 02-27-14, 02:28 PM
  #74
CatManD3W
CatManD3W's Avatar
Hahaha.....you have no idea....
Old 02-27-14, 02:34 PM
  #75
babowc
babowc's Avatar
You make fast work of things!
Quick Reply: CatManD3W SC300 Ongoing Build...
