Has anyone dropped the W58 transmission on jackstands?
Old 07-19-13, 12:13 PM
marshall2j
marshall2j's Avatar
Default Has anyone dropped the W58 transmission on jackstands?
I may have a rear main seal leak on my car.... I may have to do this within the next couple weeks in my garage.... for those who has done it, any advice? I've done a clutch change on my Supra but it was on a lift, I'm hoping this is not too bad.
Thanks
Jeremy
Old 07-19-13, 09:35 PM
Supruxes
Supruxes's Avatar
i had to drop a TR3650 out of my Mustang GT i had last year on jackstangs, best advice i can give you, is to try and get it as high in the the air as safe as possible, and make sure you have a buddy that can help you.
Old 07-19-13, 09:48 PM
INTIMAZY
INTIMAZY's Avatar
A trans jack from harbor freight makes it 10x easier to put back in. Worth the ~$50.
Old 07-19-13, 10:21 PM
SChema
SChema's Avatar
Make sure you pick up a 17mm swivel socket and some long extensions, the two top bolts under the head are a bit tricky to reach.
Old 07-19-13, 10:43 PM
jwin
jwin's Avatar
don't use the U joint swivels. Try to get the ball joint swivels. You will need about 4 feet of extension with an impact makes life easy. I have done a few on jackstands which isn't a big deal without a tranny jack by myself. The tranny isn't that heavy. I would start with the two hardest bolts and work my way down.
Old 07-21-13, 02:50 PM
Bleak
Bleak's Avatar
I did this exactly in my SC300 when I was doing my 1JZ swap. The trick is to have a very heavy duty jack stand underneath the transmission ready with a board or something to keep it balanced on the way down. Once you have the car safely on jackstands as high as possible and the transmission bolts/driveshaft disconnected just slowly jack the tranny down. Yeah- you could potentially drop the tranny on the floor, so just be careful and be ready to brace the weight when it's loose.
Old 07-22-13, 04:52 AM
marshall2j
marshall2j's Avatar
Thanks guys, I'm going to grab that HF transmission jack just to be sure.
Old 07-22-13, 10:15 AM
fried_rice
fried_rice's Avatar
I undo the driveshaft and place a jack under the transmission cross member, then lower the trans down, this helps with the top bolts. might have to raise it back up to get some other bolts though. You can get to one or two top bolts from the engine bay, each side. After that I just use a floor jack under the tranny and wrestle it out. It's a PITA, but I've done it a bunch. I've also used straps to strap the tranny to the floor jack for extra insurance. With a transmission jack or two people it would be easy.
Old 07-22-13, 10:28 AM
05Mdriver
05Mdriver's Avatar
this is going to be tough on jack stands... especially if it has to come out on an angle. good luck man
Lextrd016
Performance
16
01-21-13 05:32 AM
S.F. Goat
01-12-11 01:16 PM
Slade
03-25-10 08:41 PM
Sintari
18
10-04-06 08:37 AM
Quick Reply: Has anyone dropped the W58 transmission on jackstands?
