8 Beeps When Unlocking The Car Help Please
Old 07-21-13, 12:50 AM
whitecel
whitecel's Avatar
Default 8 Beeps When Unlocking The Car Help Please
Hey guys,
Recently my car has been intermittently making 8 beeps when using the keyless entry to the car. Sometimes it does the standard 2 beeps, but other times it does 8 beeps. Anyone can chime n on what's going on? It's annoying
Door actuator problem? But from inside I can unlock all 4 doors with the switch.
Any help would greatly be appreciated.
Old 07-21-13, 11:48 AM
chi123
chi123's Avatar
Originally Posted by whitecel
Hey guys,
Mine sometimes use to do that but I noticed when you unplug the master door switch for a minute or so and the battery as well, it doesn't do it anymore. Try unplugging the switch and see if that works.
Old 07-21-13, 12:17 PM
1Clean06IS
1Clean06IS's Avatar
yea, that just happened to me when I had all of the switches out to wrap my Trim in CF Vinyl. When I unlocked the door to re-install it beeped a bunch. Pull the trim, disconnect and reconnect the quick plugs and you should be good.
Old 07-21-13, 07:50 PM
lammy2012
lammy2012's Avatar
I had 2 actuators go bad in the same week. I would beep like that all the time until I just replaced them. Next time it happens, see if other doors are unlocked. Also, if an actuator goes bad,, the car won't beep when locking from outside the drivers door. You'll have to manually lock that door with the bad actuator and then it will beep once to let you know all doors are secure.
Old 11-07-14, 05:02 PM
sjgIS350
sjgIS350's Avatar
Default Trim removal
Are you talking about the trim around the door handles? How is that trim removed?
Old 11-07-14, 08:58 PM
5gears-IS
Great Deal Guru
5gears-IS's Avatar
Default ..................
I just noticed my is350 was doing the same and guess what? It was a warning sent from my keyless remote key telling me it had low battery. I replaced the battery and bingo beeps gone.
PandaGS300
12-05-16 07:29 PM
cruss
04-16-13 02:52 PM
spxChrome
30
09-30-10 01:24 PM
mdpuff
07-22-10 02:09 PM
Quick Reply: 8 Beeps When Unlocking The Car Help Please
