Two Years of Ownership Before/After
Old 07-22-13, 10:03 PM
Hayk
Hayk's Avatar
Default Two Years of Ownership Before/After
Inspired by Megafast's latest thread, here are the biggest changes since I purchased the car in 2011.
The "before shots" were taken before purchasing the car.
Deer busted headlight
Mismatched tail lights
Passenger Door
Front brakes were seized
New battery, all new fluids, gaskets, belts, pulleys, hoses, etc.
Engine overhaul (valve covers, spark plugs, PCV)
Dirty Interior
Old 07-22-13, 10:04 PM
Hayk
Hayk's Avatar
Stained Carpets
Burned out radio lights
Suspension overhaul
FSB
RSB
Fixing the CEL. Wrong sensor was installed.
Old 07-22-13, 10:25 PM
PuReChaos
PuReChaos's Avatar
Damn, lookin' great.
Really impressed by the carpet before and afters, what did you use?
Old 07-22-13, 11:32 PM
Hayk
Hayk's Avatar
Rented a Rug Doctor from my local Shop Rite. More info can be found here:
https://www.clublexus.com/forums/es3...s-of-dirt.html
Old 07-23-13, 02:11 PM
coffee4000
coffee4000's Avatar
Nice looking car. How did you get the dent out of the rear fender. I have the same dent. I tried to bang it out from under behind the bumper but I couldn't get a good angle on it.
Old 07-23-13, 04:25 PM
mdbrown
mdbrown's Avatar
Nice work. Did you ever figure out and fix the knocking noise over bumps?
Old 07-23-13, 06:09 PM
Hayk
Hayk's Avatar
For the rear fender, I removed the carpeting inside the trunk. My dent was right above the tail light, so it was easily accessible. I used a piece of wood and a hammer to pop it out and then sanded/touched up the area with some paint. It looks like crap, but better than before. A professional repair would cost me almost $1000 for the rear quarter.
As for the bumper, I removed the whole bumper cover and pushed the dent out with a heat gun.
I did! It turned out to be the hood latch. I raised the little rubber stoppers inside the engine bay to put more tension on the lock, and it eliminated the noise. Check this out:
https://www.clublexus.com/forums/8026132-post20.html
Old 07-23-13, 07:03 PM
mdbrown
mdbrown's Avatar
Cool. Was it a process of elimination or did you notice something with the hood?
Old 07-23-13, 07:15 PM
Hayk
Hayk's Avatar
A little bit of both, just thought I should give it a try and it worked.
Old 07-23-13, 07:50 PM
EEngineer
EEngineer's Avatar
nice work!
fleishelja
Southeast
08-20-11 01:45 PM
NU350
Canada
13
07-23-11 01:37 AM
td311
Build Threads
35
07-10-11 01:30 PM
kostas86
Local Events
05-15-11 06:42 PM
joe80
02-03-10 09:10 AM
Quick Reply: Two Years of Ownership Before/After
