Timing retard on 1UR
Old 07-27-13, 01:35 AM
chinewalk
chinewalk's Avatar
Default Timing retard on 1UR
Are there any known timing control systems or ways to manually retard base timing? Im going to be running a water/meth injection system and twin stage nitrous. Being able to retard the timing would be very helpful.
Old 07-27-13, 08:22 AM
XxGoKoUxX
XxGoKoUxX's Avatar
I've never heard of Methanol/water injection working together with nitrous before, I've used it for FI applications to help aid the intercooler though. How does that work in conjunction chinewalk? (I've never used nitrous, so it's a legitimate question lol).
You should check on the IS-F forums and see if any of them are running nitrous..... I saw on youtube Steve Meade was using Nitrous on his IS-F (mild though, so I doubt twin-staged) and had great results.
Old 07-27-13, 11:02 PM
designo
designo's Avatar
Old 07-27-13, 11:09 PM
ibidu1
ibidu1's Avatar
Ive seen that car run at the BIC, that ISF is def a nasty beast!
Old 07-28-13, 11:45 PM
chinewalk
chinewalk's Avatar
I havent been able to find any ISFs with spray that have done any modification to the factory ecu yet. They seem to be able to take a decent amount of spray on a stock motor. As far as the water meth it works great with nitrous. Cools cylinder temps and increases the effective ocatane, im doing whatever i can do avoid detonation. I have also decided to run e85 in my standalone fuel tank.
Old 07-28-13, 11:46 PM
chinewalk
chinewalk's Avatar
I would like to do direct port but the manifold is plastic on the gs
Old 07-29-13, 08:50 AM
XxGoKoUxX
XxGoKoUxX's Avatar
Wow, I did a looong search for you, and you're right! Everyone's running off stock setup, no timing retard on their cars... GL Chinewalk
idoke1
IS F (2008-2014)
360
05-27-22 08:30 PM
MileHIFcar
GS F (2016-present)
01-13-19 07:52 PM
CBR169
IS F (2008-2014)
03-06-18 06:51 PM
adplusone
IS F (2008-2014)
09-18-14 06:00 AM
Quick Reply: Timing retard on 1UR
