IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
ABS and Trac off Light - Help please
Old 08-05-13, 02:12 PM
nwchopper
nwchopper's Avatar
Default ABS and Trac off Light - Help please
Hi,
I have a 2001 Lexus IS300 and the ABS light and Trac off light are continuously on.
I first had the P0161 code, so I replaced the O2 sensor and the code went away.
Then I had the P0505 code, so I cleaned the throttle body and the code went away.
I thought replacing the O2 sensor would remove the trac off and abs light but it didn't.
Does any have any other suggestions? Is it possible that my abs sensors could require replacing?
Thanks.
Old 09-05-13, 06:14 AM
leoentz
leoentz's Avatar
you might have to change the Abs sensor. i hade the same problem, front passenger side had to be changed.
Old 09-10-13, 04:56 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Unfortunately, there are a lot of potential causes... need to obtain a scanner that is capable of pulling ABS codes and go from there...
aymaddemir
02-25-17 11:24 AM
allenliu47
RX - 1st Gen (1999-2003)
03-20-16 04:19 PM
Clarkie168
Performance
07-28-12 04:17 PM
Lexs400
Maintenance
09-12-09 01:25 PM
Quick Reply: ABS and Trac off Light - Help please
