08 ls 460L vibration
Old 08-28-13, 01:14 PM
gtower
gtower's Avatar
Default 08 ls 460L vibration
Hello, I'm new to Lexus ownership and have recently purchased an 08 certified LS 460 L with the air ride suspension. It's a phenomenal car, I'm now a convert to the brand. One small thing I noticed though is a slight jiggle or vibration coming to the steering will at moderate speeds. It is very dependent on the road surface, Seems to dissipate on the highway. Alignment was checked before delivery and feels fine and the tires themselves feel balanced. It's not upsetting, I'm just curious if this is something normal to the air ride suspension. Other than this the car is an absolute gem with only 35,000 miles.
Old 08-28-13, 01:32 PM
CJITTY
CJITTY's Avatar
Been discussed several times. There is a TSB to fix driveline vibration issues with some models..many of us have that issue. Doesn't always show up and may not be your issue. Recommend getting a road force balance on tires first..if still doing it after that.. make sure your front calipers are not sticking and maybe keeping the pad on the rotor
Sent via Club Lexus Mobile App
Old 08-29-13, 10:46 AM
gtower
gtower's Avatar
Ok good info. I'll start with a balancing. A little disapointing as this was a certified car and should have been caught before delivery.
Oh Well
Old 08-29-13, 04:00 PM
I8ABMR
I8ABMR's Avatar
I have been the king of vibration on this forum. Could be the balance, tire defect ( tread goes side to side as it spins or out of round), or driveline issue. I had my driveshaft replaced, wheels replaced, and tires replaced. For me I had two defective rear tires that created the vibration. I went with Michelins and its much much better but there is still a hair of vibration. I have had three dealership, Shop foreman, and a Lexus engineer fly out from LA to check the car only to find that it was the tires.
Like they say in medical school " when you hear hoof steps think horses not zebras" . start with the obvious then dive into the rare stuff.
Could also be the upper control arm bushings. There was a TSB on them too.
Old 08-29-13, 05:47 PM
caha14
caha14's Avatar
Now that's a shared crown...
gtower, I sent you a PM as I see you are local.
rustytank
ES - 6th Gen (2013-2018)
06-14-14 06:27 PM
lex460l
02-23-14 11:59 PM
centurion4
01-28-14 08:03 AM
NobleSpine
12-20-12 01:58 AM
LexFan87
08-10-07 09:18 AM
Quick Reply: 08 ls 460L vibration
