20 ton press useful?
Old 08-28-13, 02:07 PM
SC3coupe
SC3coupe's Avatar
Default 20 ton press useful?
I am thinking of getting a press from harbor freight..
Does it work on the bushings replacements that our car has, press bushings out and put new ones in? Somehow I have noticed there are pressable and non-pressable version of the bushing sold?
one thing I am not sure about doing is the LCA bushing, by the time I separate the ball joint and put it back, the ball joint is probably in worse shape and I might as well buy a new LCA
Old 08-28-13, 02:24 PM
estomax
estomax's Avatar
i used a harbor freight press to do my bushings. it felt sketchy cause the press was twisting but it did pop them out.
Old 08-28-13, 05:48 PM
INTIMAZY
INTIMAZY's Avatar
The press works fine. The worst part is the less-than-sturdy frame but it handles the load.
Old 09-04-13, 12:36 AM
Swint
Swint's Avatar
My buddy has one and it worked fine for the suspension bushings.
Old 09-04-13, 07:22 AM
Ali SC3
Ali SC3's Avatar
I didn't have a press I had to burn those bushing out it was like a rubber bbq.
next time I will get new control arms and not mess with it.. lol
Def. check your ball joint.
Old 10-31-13, 11:28 AM
GTE4Life
GTE4Life's Avatar
I used a quality press at a buddys shop on my GS bushings and it was a life saver (the caster arms require a press for the new bushings), but i would warn you that they can be dangerous. especially if you are pressing an oddly shaped arm (like the GS caster arm), they become hard to stabilize on the press bed and will pop and jump with a ton of force (one arm flew about 5 feet in the air). That said they can be really useful, i have heard of people buying the cheap harbor freight press then welding the frame in addition to the bolts and even welding some reinforcement bars to the frame, this is the route i am going to go when i buy a press.
Old 10-31-13, 01:12 PM
Answer300
Answer300's Avatar
every bushing that ive replaced was pressed out with a 12 ton press. you really dont need 20 ton. btw mine is a harbor freight unit
Old 10-31-13, 11:14 PM
Dawa
Dawa's Avatar
a press is an awesome thing to have for the home mechanic
markdav801
01-17-18 10:56 AM
Slvr surfr
12-30-15 07:24 PM
GSquicksilver
Suspension and Brakes
14
10-28-09 07:58 PM
757jetip
13
02-11-07 09:17 AM
EUROJulian
82
05-31-04 12:55 PM
Quick Reply: 20 ton press useful?
