What is this part attached to the throttle body?
Old 09-01-13, 12:06 AM
CLightning
CLightning's Avatar
Default What is this part attached to the throttle body?
I was taking off the throttle body to replace the driver side coolant line and the cap (see "b" in pic) of this part partially broke off. It looks like heat and time made it very brittle. Inside the unit, there's a screen filter. The cap seems salvageable as a little silicone sealant around the edges might be able to seal it back up. So what is it and is that cap replaceable? How much $? Thanks.
Old 09-01-13, 04:27 AM
F4A22
F4A22's Avatar
That's your diaphragm.
Old 09-01-13, 08:00 AM
BiGEZ
BiGEZ's Avatar
Do not seal the cap on too tight with the silicone it is suppose to vent some air out when actuating.
Old 09-01-13, 06:01 PM
MooJohn
MooJohn's Avatar
It acts as a cushion when you abruptly let off the throttle, keeping the plate from slamming shut all at once.
lexus-is2
05-09-13 12:43 PM
mishkinm5
IS F (2008-2014)
07-13-12 04:20 PM
broda805
01-23-11 07:26 AM
spxChrome
03-26-03 06:10 PM
Quick Reply: What is this part attached to the throttle body?
