Key Fobs Stopped Working
All the key fobs stopped working on my wife's 2006 GX. I didn't see an answer after a quick search. Does anyone have some ideas on what could be the problem. A big thanks in advance!
Forum Administrator
Assume you replaced the fob batteries already?
Link to thread with battery info
https://www.clublexus.com/forums/gx-...y-key-fob.html
Sounds wierd both at same time but it can happed as both my Drivers and passenger door lock actuators went out at the same time--No lie!! replaced under warrrenty.
Both my batteries died in two key fobs within a week. I could understand that since they were both probably replaced at the same time and used equally. Walgreens took me for $5.5 since I needed one immediately. 5-pack from amazon on the way for $3.3
If not the key-fob batteries, check for blown fuses.
Not sure where the receiver is on the GX, but in other cars I've had it was located in the driver's door, and sometimes a wire through the door boot would break.
Chip H.
Chip H.
vdeyfi
GX - 1st Gen (2004-2009)
04-17-12 09:30 PM
