Lexus To Launch Updated CT 200h Next Year, Eventually Offer More Variants: Report
Old 10-15-13, 01:30 PM
  #46
nabbun
nabbun's Avatar
Originally Posted by ydooby
In Europe the CT and the Prius get practically identical fuel economy ratings (the CT beats the Prius slightly there actually). It's only in the US where the CT comes standard with 17" wheels (versus 15" in Europe) that the CT mysteriously trails the Prius by that kind of margin.
Oh wow. I didn't know that! That's another HUGE factor!
The Camry Hybrid LE beats out the Hybrid XLE by a small margin because the XLE has the heavier alloy wheels and weighs a tad more.
This makes perfect sense.
nabbun is offline
Old 10-15-13, 03:09 PM
  #47
Hoovey689
Hoovey689's Avatar
Originally Posted by Blueprint
Completely agree, but 40 MPG for a good size sedan and then 40 MPG for the hatch AND the sedan makes 200hp to the CT 138hp means the CT could hopefully get 50 MPG with its current engine or the new engine from the ESh.
Or maybe a bump to 45MPG. Not sure why the CT loses 10MPG from the Prius outside of aggressive engine mapping in sport mode.
Keep in mind the tiny 1.8L in the CT has to work harder than the 2.5L in the ESh. Honestly I think the CT would get some great mileage and good performance boost from the ESh, Camry Hybrid, Avalon Hybrid powertrain
Hoovey689 is offline
Old 10-15-13, 03:15 PM
  #48
LexFather
Guest
Posts: n/a
Thanks ydooby. Thing is that cannot be the only reason. I went from 245/40/18 to 245/30/20 and 285/25/20 and noticed no difference in MPG...maybe its just me
Old 10-15-13, 10:40 PM
  #49
spwolf
spwolf's Avatar
you driving it and EPA test cycle have nothing in common :-)
In general, EPA test is stricter than NEDC in Europe. Also probably higher speed and due to CT200h being hatchback, Prius is actually a lot more aerodynamic.
And in reality, tests are being cheated on.
We can see some real info on FuelEconomy.gov, it certainly isnt perfect but its usable:
- Prius - 49 MPG (50 MPG)
Prius c - 51.5 MPG (50 MPG)
- CT200h - 43.8 MPG (42 MPG EPA)
- Camry hybrid -- 40 MPG (40 MPG EPA)
- Fusion Hybrid - 39.9 MPG.(47 MPG EPA)
So I would expect CT300h to get real life 40 MPG, which nobody would complain about :-).
As to the tests, as we can see, Toyota could have probably made their hybrids get higher mpg on the test, but what then? Is that actually good?
spwolf is offline
Old 10-16-13, 04:32 AM
  #50
Received 2,126 Likes on 1,378 Posts
It's only in the US where the CT comes standard with 17" wheels (versus 15" in Europe)...
had to go look.
UK CTh
Attached Thumbnails Lexus To Launch Updated CT 200h Next Year, Eventually Offer More Variants: Report-ukcth.jpg
bitkahuna is offline
Old 10-16-13, 06:04 AM
  #51
Vladi
Vladi's Avatar
CT would benefit from 300h powertrain but it will probably not happen until next gen.
Vladi is offline
Old 10-16-13, 07:24 AM
  #52
spwolf
spwolf's Avatar
had to go look.
UK CTh
you should see 520ed wheels... worse than those :-)
CT200h also has 16" wheels if i remember correctly... in any case, under European MPG testing, it gets same mpg as Prius with same wheels.
spwolf is offline
Old 10-16-13, 07:34 AM
  #53
bagwell
bagwell's Avatar
I think its the actual weight of each wheel that has the most meaning not the size - on my 3G Prius the standard 15" wheels were feather-lite versus the OEM 17" I swapped to....huge difference.
bagwell is offline
Old 10-16-13, 08:34 AM
  #54
Sulu
Sulu's Avatar
...weight and the width of the tire patch. Switching from 15" to 17" gives you a lower-profile but wider tire. More tire touching the road gives more friction.
Sulu is offline
Old 10-16-13, 11:08 AM
  #55
nabbun
nabbun's Avatar
It won't. ToMoCo execs have said so after the launch of the CT200h.
nabbun is offline
Old 10-16-13, 11:10 AM
  #56
nabbun
nabbun's Avatar
Weight of tires, Low Rolling Resistance technology, Weight of wheels (regardless of size) will affect mileage. People with the Camry Hybrid XLE who have swapped to the steelies from the LE have noticed an improvement on their mileage. I bet I'd see a bump in mileage if I went from the F-Sport 17's to the EU's 15's with the same type of tire that we're using now. Grand Touring All-Seasons with LRR technology.
nabbun is offline
Old 10-16-13, 01:32 PM
  #57
bagwell
bagwell's Avatar
not necessarily
bagwell is offline
Old 10-16-13, 02:16 PM
  #58
spwolf
spwolf's Avatar
not necessarily
its 195 to 215 in this case...
they actually test MPG of every version in Europe, and fully equipped CT200h with 17" is 10% thirstier in official tests... obviously it is also weight of extra equipment that makes the difference.
spwolf is offline
Old 10-16-13, 04:28 PM
  #59
Sulu
Sulu's Avatar
not necessarily
Replacing a 15" tire with a 17" tire on the same car -- meaning retaining the same tire diameter -- will give you a wider tire.
Sulu is offline
Old 11-06-13, 09:45 AM
  #60
Vh_Supra26
Vh_Supra26's Avatar
Default Scoop: Spindle Grille 2014 Lexus CT 200h F-Sport Caught Without Camo
Click here to view more photos
If last month's brochure scans of the mildly updated 2014 CT 200h weren't convincing enough for you, then perhaps these scoop photos of a camouflage-free prototype of Lexus' compact hybrid will do the job.
The model that was captured on camera by our scoop photographers is the more dynamic looking and handling F-Sport edition, which in its refreshed form, features the Lexus brand's now signature pinched grille flowing above the redesigned bumper with a large plastic honeycomb insert and satin silver trim.
The only other noticeable styling changes on this car are the new alloy wheels and the reworked rear bumper with a different diffuser. Similar cosmetic updates should be applied to the regular CT 200h hatchback.
Whether Lexus has also altered the compact model's interior and hybrid powertrain remains unknown at this time.
Look for the 2014MY to make its debut in one of the international motor shows in the following months.
http://www.carscoops.com/2013/11/sco...s-ct-200h.html
Vh_Supra26 is offline
Quick Reply: Lexus To Launch Updated CT 200h Next Year, Eventually Offer More Variants: Report
