Need help from someone with a soarer 1jz swap
Old 10-18-13, 05:53 PM
VisiSC
VisiSC's Avatar
Default Need help from someone with a soarer 1jz swap
I am currently repairing part of my soarer harness which runs to the Igniter, and I need someone to help me out by taking a picture of the wires to their igniter plug, or just post on here with the color order of the igniter wires. I've found pictures online but they aren't clear enough to make out the wires correctly. If someone could do that and post them here, or send them to me that would be amazing. Thanks in advance!
Old 10-19-13, 04:17 AM
Vrank
Vrank's Avatar
I would use pinouts instead. Color can get you in trouble. Google search 2jzgte igniter pinout and jzz30 pinout. Or google search 95 mk4 tsrm. I used mk4 gte diagrams as a reference when I built my gfs aristo harness for her sc. Circuitry is the same. So just trace from igniter to ecu, 1j functions are named the same. Ex: igt is pin X at ecu, goes to igniter pin x. Igc at igniter pin x goes to coil x, etc
Old 10-19-13, 09:12 AM
VisiSC
VisiSC's Avatar
I feel pretty dumb now, but thanks for the help. The pinouts were easier to use than I thought.
6SOARER
09-05-11 07:35 AM
esssee400
05-03-11 09:02 PM
wilsonsan
GS - 1st Gen (1993-1997)
04-11-11 01:06 AM
americk22
01-30-11 09:32 PM
ZGagnon
07-09-10 01:00 PM
Quick Reply: Need help from someone with a soarer 1jz swap
