NaT questions
Old 10-25-13, 03:32 PM
JustChill
JustChill's Avatar
Default NaT questions
So is it okay to remove all the egr systems? Why is this done? Also what do u with the extra hole in the valve cover now that the egr system is not in place?
Old 10-25-13, 03:58 PM
turbodremz
turbodremz's Avatar
Only issue with removing the EGR system is the CEL that will be given. Its done to eliminate some of the BS vacuum lines that are under the hood and clean some of the air going into the intake tract. There are block off plates available online for the deleted EGR system, or if you have the means, you can make your own.
Old 10-26-13, 04:16 PM
SCstone
SCstone's Avatar
exhaust gas recirculation . its mainly for US emissions
The2JZFTW
11-19-23 07:26 AM
nobelnabil
02-09-18 09:34 PM
reexist
01-03-18 11:32 AM
SupraCoup3
17
09-04-12 07:15 AM
Inabj2
Maintenance
06-04-05 04:51 AM
Quick Reply: NaT questions
