Aftermarket Tires
Old 11-14-13, 07:55 PM
Stitch626
Stitch626's Avatar
Question Aftermarket Tires
What aftermarket tires do you guys prefer or recommend? I'm tire shopping and need some help and ideas!
Old 11-14-13, 08:17 PM
Dawa
Dawa's Avatar
depends on what youre after. some tires are more (quiet/louder/stiffer/heavier/fatter side wall/etc/etc/affordable/perform better/wores in certain climates) than others
Old 11-14-13, 08:28 PM
Stitch626
Stitch626's Avatar
def quiet tires and a nice sidewall would be nice to help protect the rims and I live in Miami so dont need all weather tires
Old 11-15-13, 08:29 AM
bucanero
bucanero's Avatar
Tirerack.com
Gets you pointed in the right direction. I always reference with them as far as UTQG rating, thread pattern, and reviews. I have never bought from them though, I probably should for using their resources.
Old 11-16-13, 07:46 AM
ybing
ybing's Avatar
I told my dealer to remove the stock Bridgestone and put on some Pilot Super Sport~
Old 11-17-13, 06:24 AM
felixlau
felixlau's Avatar
I'm using Goodyear F1 AS2 ..... To me, they are great !!
Smooth running, good grip, not too noisy and they just gives u confidence round corners !
Old 11-17-13, 11:29 AM
UncleSpud
UncleSpud's Avatar
+1
I wish I had done the same. When I wear out the Bridgestones, I'm going for the Michelin Pilot Super Sports. I'm currently running them on my Mustang (they were not OEM on the car), and they're terrific. Only disadvantage is price--I paid $305/tire at Tirerack for four 255-40-19 tires. If you don't have the coin, a good alternative is the Continental Extreme Contact DW, which is much less expensive.
You might also consider running the same size wheels/tires X 4, if you're upgrading rubber. Two advantages: you can rotate your tires and you'll have less understeer.
Old 11-17-13, 07:38 PM
bucanero
bucanero's Avatar
Those were the ones I decided on as well. Can't wait to get them mounted.
Old 11-18-13, 03:41 AM
Stitch626
Stitch626's Avatar
Thanks for all the info fellas, I've decided on the NITTO INVO going to run 235/35/19 up front and 265/30/19 in the rear
Old 11-20-13, 09:51 AM
neilvosko
neilvosko's Avatar
i am looking to run square 245s a bit taller tire on OEM Fsport Conti EC DW
Old 11-21-13, 03:49 PM
KumaF
KumaF's Avatar
Has anyone used Continental ExtremeContact DWS before? I heard a lot good things about it, especially winter performance. But there are also complaints about its sidewall being soft. I just wonder if anyone here can comment on that.
MsLucy350
Wheels, Tires & Brakes Forum
03-10-15 07:21 AM
carrwash13
03-17-11 03:42 PM
mrblister
08-11-10 05:59 PM
kloh7
01-31-07 01:47 PM
JohnnySC
10-18-02 02:34 AM
Quick Reply: Aftermarket Tires
