HOW TO: Change light bulbs in center console and temperature control buttons
Old 11-23-13, 04:36 PM
yuri.ber
yuri.ber's Avatar
Default HOW TO: Change light bulbs in center console and temperature control buttons
Hey guys, I finally addressed a burnt center console light bulb problem and decided to do a how to in case someone needs to do it and is afraid something is going to go wrong.
Tools needed:
Regular (+) screwdriver
Small thin blade (-) screwdriver
Small pry bar
Bulb part #s:
90010-01059 for suspension mode, PWR/SNOW. One bulb for each button so 3 bulbs needed.
90010-01070 for vsc, rear sunshade etc. One bulb for all four buttons so 1 bulb needed.
90010-03043 for temperature control. One bulb needed.
Here's how my center conole looked:
All of suspension mode and power/snow, vsc and headlight washer buttons were not lit.
To get the bottom panel out no tools are needed, just open the storage compartment on the right and pry the pannel with your fingers:
Then you'll see three screws that hold the top panel. Use cross screwdriver to take them out:
Take the upper panel out:
I took the cover off the bottom panel to show you where the bulb is and that there's only one:
Here you'll need a small, thin blade (-) screwdriver. Turn counter clockwise to get the bulb out, clockwise to lock the new bulb in place:
Now for the upper panel.
Each of three buttons are separately held and are taken out by hands. Hold each button from the back and wiggle out pressing from the front with another hand.
Each button has its own bulb, it's on the side. Change the bulb the same way as described above:
Temperature bulb.
Use a small pry bar to he the temp switch out:
Bulb is located on the side at an angle. Change the bulb out same way as described above:
Now all can be put back together, upper panel first. Don't forget to connect all cables back.
After:
Old 11-23-13, 08:22 PM
BT3100
BT3100's Avatar
Great post.
Thank You!
I need to replace the exact same bulbs in my 02 UL.
Appreciate the time you took to detail this.
Old 11-24-13, 07:11 AM
yuri.ber
yuri.ber's Avatar
You're very welcome. It took me less than 20 minutes to do the bulb change including taking pics. It is easy to do.
Old 11-24-13, 07:17 AM
Lavrishevo
Lavrishevo's Avatar
Nice. I had a few bulbs out on mine too and had the car stereo shop do it when they were replacing my sub and installing the Grom adapter. Should add this the FAQ section.
Old 11-24-13, 12:49 PM
L8RSk8R
L8RSk8R's Avatar
AWESOME!!
I've needed to do this, for over a year now :/
Old 02-09-14, 07:04 AM
jlmeinke
jlmeinke's Avatar
Can you change the green lights to white lights?
Old 02-09-14, 08:48 AM
LiCelsior
Retired
LiCelsior's Avatar
yes you can, just buy led replacement bulbs. i ordered the NEO4-WHP 4mm NEO4-xHP Cool White from superbrightleds.com and they are nice and bright.
Old 02-09-14, 09:36 AM
username32
username32's Avatar
Did you get the white ones? Got any pics of how they look? Ive heard alot of LED's leave a hot spot since light spread isn't uniform.
Old 02-09-14, 11:23 AM
Tom57
Tom57's Avatar
Can the bulbs in the radio be replaced? I have 1 bulb out in radio behind the On-Off / Volume ****.
Old 02-09-14, 02:09 PM
Lavrishevo
Lavrishevo's Avatar
Yes, they can be replaced.
Old 02-09-14, 03:01 PM
Tom57
Tom57's Avatar
Are the bulbs in the ML radio Lexus dealer bulbs? Part #? How do you access the radio bulbs? Thanks.
Old 02-09-14, 05:07 PM
writes123
writes123's Avatar
On a related issue that I have, can anyone help with the gearbox/transmission shifter (P, D, L etc.) lighting not turning on at night while all the other center console lights up? Is there a setting that or adjustment that needs to be made to turn that lighting on?
Or if it is a bulb issue, does anyone know the part number and how to replace it? Thanks.
Old 02-09-14, 05:17 PM
Lavrishevo
Lavrishevo's Avatar
Yeah, it's probably all lamps.
Take a loot at this. Look at the various diagrams. There all there somewhere.
http://www.lexussouthatlantaparts.co...001001059.html
Old 02-09-14, 05:27 PM
LiCelsior
Retired
LiCelsior's Avatar
theres no hot spotting, the button itself is so small its perfect.
Old 02-09-14, 07:17 PM
Tom57
Tom57's Avatar
Lexus Parts Manager advises there is no Lexus part # for radio bulbs. I don't see any on the diagrams either.
Quick Reply: HOW TO: Change light bulbs in center console and temperature control buttons
