Headlights problem?
Old 12-05-13, 05:17 PM
genebest
genebest's Avatar
Default Headlights problem?
I get 2008 Lexus RX 350 recently. I just put new battery. The problem is:
when I turn on low beams or high beams the instrumental panel lights (dashboard) become off.
Only DRL running with instrumental panel lights on.
How can I fix the problem, any advise?
Old 12-05-13, 05:22 PM
RX330inFL
RX330inFL's Avatar
Welcome to Club Lexus, .
Have you tried adjusting the brightness for the instrument panel using the Instrument panel light control? See page 129.
http://drivers.lexus.com/t3Portal/do.../sec_02-02.pdf
Old 12-06-13, 05:37 AM
kjv1611
kjv1611's Avatar
Thumbs up Thanks for posting link to the PDF
Is there any way to say "thanks" in these forums other than saying it? I know many forums have different ways of doing this - marking correct answer, helpful, whatever.
But thanks to RX330inFL for posting the link. I just got my RX350 about 2 weeks ago, and have lots of learning to go... but I did figure out pretty quickly to use the dimmer **** for the instrument panel.
Old 12-06-13, 05:41 AM
kjv1611
kjv1611's Avatar
Okay, how do you get to the full manual / document referenced? I found another area I need to read more on - cruise control - b/c mine was broken when I bought it.
Old 12-06-13, 10:13 AM
RX330inFL
RX330inFL's Avatar
You can search the Owner's Manuals for all vehicles here:
https://secure.drivers.lexus.com/lex...nual-search.do
If you need a new Owner's Manual for your vehicle Lexus Customer Service will more than happily send you a new one.
Old 12-06-13, 11:03 AM
jakenbake
jakenbake's Avatar
You have the brightness turned all the way down. Turn the **** back up.
Old 12-17-13, 07:42 AM
kjv1611
kjv1611's Avatar
Thanks, RX330inFL! I'll be sure to take a look!
Old 12-17-13, 12:46 PM
RX330inFL
RX330inFL's Avatar
No problem. BTW, you should also take the time to register your new ride with Lexus here -- just have your VIN available:
https://secure.drivers.lexus.com/lexusdrivers/home
That will give you access to any past Lexus service information provided along with recall information. You can also order up the new Owner's Manual there as well. Either way you ask it is free of charge.
Old 01-13-14, 11:47 AM
kjv1611
kjv1611's Avatar
Awesome! Thanks again! I'll be sure to do that... hopefully this week, assuming I don't forget.
Old 01-13-14, 11:48 AM
kjv1611
kjv1611's Avatar
Sorry took so long to respond, by the way - hadn't been on here in a while.
rVague
12-21-18 04:16 PM
IS350atWOT
RX - 3rd Gen (2010-2015)
02-17-12 05:18 PM
jewelberry
05-24-11 10:17 PM
kms910
09-18-06 12:51 PM
shikbas
01-16-06 08:58 AM
Quick Reply: Headlights problem?
