Wheels and Tires Classifieds All rims and tires for sale belong here.
NM 08 ISF rims w/tires (complete setup)
Old 01-04-14, 06:53 AM
clifftrail
clifftrail's Avatar
Default 08 ISF rims w/tires (complete setup)
This is a complete set of factory BBS rims w/tires from a 08 Lexus ISF. It includes all you see, the tires are mounted, balanced and have working tire pressure sensors installed. The tires have approximately 10K miles on them and have lots of life left. You'll see in the pics that they aren't even close to the OEM wear bars in the grooves.
I'd rate three of the rims as a 10 of 10 condition and one of the rear rims has some curb rash that was touched up so I'd give that an 8 of 10.
These are directional tires and a staggered setup. The tires are Bridgestone Potenza RE050A and the fronts are 225/40/19 and rears are 255/35/19.
The rims are a 114.3 bolt pattern with fronts being 19x8 with a 45 offset. The rears are 19x9 with a 55 offset.
Price is $1600 shipped to include all fees for the CONUS 48 states (no Hawaii or Alaska). Shipping internationally will cost more so if your interested be prepared for a higher price to cover fees.
Thanks for looking.
Attached Thumbnails 08 ISF rims w/tires (complete setup)-dscn0923_1314.jpg   08 ISF rims w/tires (complete setup)-dscn0924_1315.jpg   08 ISF rims w/tires (complete setup)-dscn0925_1316.jpg   08 ISF rims w/tires (complete setup)-dscn0926_1317.jpg   08 ISF rims w/tires (complete setup)-dscn0927_1318.jpg
clifftrail is offline
Old 01-04-14, 06:55 AM
clifftrail
clifftrail's Avatar
Default Pics of tires
Tires ... tire pressure sensors do work, I had this set programmed for the car to recognize when installed and you'll be able to do the same.
Attached Thumbnails 08 ISF rims w/tires (complete setup)-dscn0928_1319.jpg   08 ISF rims w/tires (complete setup)-dscn0929_1320.jpg   08 ISF rims w/tires (complete setup)-dscn0930_1321.jpg   08 ISF rims w/tires (complete setup)-dscn0931_1322.jpg
Old 01-04-14, 03:57 PM
Jamsheddy
Jamsheddy's Avatar
Will these fit a GS without any issues. Meaning I won't need hub centric rings or anything?
Jamsheddy is offline
Old 01-04-14, 04:46 PM
clifftrail
clifftrail's Avatar
No idea, ping the GS guys. I'm sure they have tried similar wheels and may know. Unless you want to drive here, test fit and drive back with them on.
Old 01-04-14, 07:24 PM
Roe
Roe's Avatar
If you have a 06 GS, no problem with these fitting. With a 07 to 11, you need at least a 10 mm spacer up front to clear the larger brake calipers.
2nd Gen GS, I have no idea.
Roe is offline
Old 01-04-14, 07:40 PM
CalitriSC
CalitriSC's Avatar
You don't need hub centric rings for and factory Lexus wheel
CalitriSC is offline
Old 01-04-14, 08:06 PM
Jamsheddy
Jamsheddy's Avatar
Good to know, thanks guys!
Old 01-05-14, 08:08 AM
clifftrail
clifftrail's Avatar
Wheels/tires sold! Thanks CL!!!
ronnymo
ES - 5th Gen (2007-2012)
23
07-07-21 05:46 PM
leisinjp
07-14-15 01:03 PM
clifftrail
01-01-14 12:34 PM
as3.0cl
04-28-11 03:19 PM
gcollier
16
04-21-08 07:16 AM
Quick Reply: NM 08 ISF rims w/tires (complete setup)
