Rattling noise on passager side
Old 01-12-14, 09:13 PM
SOLOPIPE4
SOLOPIPE4's Avatar
Default Rattling noise on passager side
I have a bad rattling noise when I go over ruff terrain and pot holes can sum one give me an idea of what this could be
Old 01-12-14, 09:26 PM
gstreee
gstreee's Avatar
Ive seen inquiries about this problem before...could be a boatload of possible things for example broken motor mounts, lower control arm bushings, swaybar end links and bushings....etc etc. i believe i saw this on an acura forum when i was interested in a tl...pssht what was i thinking anyways i rem the problem being consistent with happening only when going over bumps and potholes...good luck with the fix
Old 01-12-14, 09:55 PM
850Lexus
850Lexus's Avatar
Strut mount is likely source. I have actually had a situation where one of the mounting bolts for the front brake caliper back out and cause the rattling.
Old 01-13-14, 01:14 PM
repugnante
repugnante's Avatar
Preaching to the choir man. It can be many, many things causing that clunk. Replace all of your suspension pieces that are considered a "wear item" and then check back
Old 01-13-14, 02:51 PM
Lukas99GS
Lukas99GS's Avatar
I had a rattling noise but it was almost all of the time, turned out to be a loose heat shield, lexus took it off for free
Old 01-20-14, 07:02 PM
SOLOPIPE4
SOLOPIPE4's Avatar
That's the exact same thing that happen to me at first I thought I forgot to put it in
Old 01-29-14, 05:58 PM
Lexino214
Lexino214's Avatar
Maybe the trim on the inside connected to the moonroof, the instrument cluster bezel, or if you had the windshield replaced it could be the guide clips under the leaf shield behind the wipers. Good luck.
StlBorn
Suspension and Brakes
04-15-23 07:40 PM
abbyNormal
11-04-15 10:41 AM
anesthesia
02-05-13 03:16 PM
ricomr
GS - 1st Gen (1993-1997)
06-17-08 01:37 AM
aerodragon
11-17-05 09:11 PM
Quick Reply: Rattling noise on passager side
