VSC check engine and traction lights?
Old 01-21-14, 09:14 AM
Stubagg
Stubagg's Avatar
Default VSC check engine and traction lights?
Hey I recently got a check engine light and traction light. The dash says check VSC. I do have after market ppe race headers. Any idea what this is? Or what it could be for?
Thank you
Old 01-21-14, 09:45 AM
madastep
madastep's Avatar
might be just that, PPE has awesome customer service, so if that's the case it shoudl get fixed quick . Did anything happen prior to all that? have you plugged it up and checked out the code it's throwing?
Old 01-21-14, 10:01 AM
4everkidd
4everkidd's Avatar
Sounds like your secondary O2 sensors.
Also that seems to be the code that PPE headers were throwing.
Search is your friend in this case; several threads have gone into depth hunting down this issue.
Old 01-21-14, 10:30 AM
Stubagg
Stubagg's Avatar
Nothing happened prior yet. I have not gotten it checked out yet.
Old 01-21-14, 10:48 AM
yjk1975
yjk1975's Avatar
Pull the fuses and reset. Search fuse reset.
If codes come back. I would check the O2 extenders on both sides. Make sure it is not touching the headers at the very top.
Old 01-21-14, 11:06 AM
DrRick
DrRick's Avatar
it took mine thru a touchless car wash and had those lights on when i got back in it. of course the owner said that it wasnt his fault. took to it the dealership and the driver side secondary o2 sensor was bent and the lines were frayed. the result of hitting 'something' in the car wash.
i KNEW better than to take it thru but it needed to be washed and i was short on time. i feel sick about it.
Orboro
IS F (2008-2014)
10-28-16 12:49 PM
I8ABMR
IS F (2008-2014)
50
02-11-16 11:44 AM
PololoISF
IS F (2008-2014)
13
11-16-15 10:44 AM
mercurymet
IS F (2008-2014)
05-26-13 07:37 AM
JDMCelsior
07-08-10 11:50 AM
Quick Reply: VSC check engine and traction lights?
