97' LS Tranny issue
Old 01-29-14, 03:25 PM
KingNasGS4
KingNasGS4's Avatar
Default 97' LS Tranny issue
Whats up guys, My father has a 97 LS
Symptoms are :
Goes into Reverse just fine.
Put it into drive and it feels as if the car is still in neutral.
Let it warm up for a while and then you have to accelerate a bit for it to engage.
After that, its fine.
Time for a new tranny? Pops thinks it might be the selector switch giving problems....
But I don't think so myself.
Let me know guys
Old 01-29-14, 03:38 PM
timmy0tool
timmy0tool's Avatar
mileage? how is the trans fluid level? it really just sounds like the car is low on ATF. remember to use toyota type T-IV only on these trans. they are sensitive to anything else just like your GS (which shares the same motor/trans).
keep in mind there is a "cold" and "hot" side to the ATF dipstick.
Old 01-29-14, 04:00 PM
Twista4004
Twista4004's Avatar
Maybe you guys have a suggestion for me while we're on the topic. I've got a 93 with the EXACT same issue description. Bought a couple quarts of T-IV and added to trans just in case it was that. Same issue. Fluid level, well past hot on the dipstick afterwards. Any pointers?
Old 01-29-14, 05:16 PM
Yamae
Yamae's Avatar
In my case, just adding the Type IV fluid fixed the problem. Now the level is slightly higher than the upper limit when hot but it is only about a few mm (0.1 Inch). The same things happened to my friends who own Celsiors. A dealer confessed me that the transmission prefers the high end of the fluid level.
Old 01-30-14, 01:20 AM
silos5
silos5's Avatar
I had something similar: on cold I put reverse, it went into reverse, but in 3 seconds it went into neutral itselt (althought the shifter was in R) ... same never happened on warm. Checked the level - too LOW. Changed the fluid and leveled it....no problem any more !!
Old 01-30-14, 08:08 AM
KingNasGS4
KingNasGS4's Avatar
thank you guys Ill pass on the message and hit yall back with results
Old 01-30-14, 08:53 AM
stephen18
stephen18's Avatar
I'm chasing the same issue,
Old 01-30-14, 11:20 AM
steve2006
steve2006's Avatar
Then check the same things
Old 01-30-14, 11:34 AM
LScowboyLS
LScowboyLS's Avatar
yes, '97 LS400 is very rare to have a transmission issue, and when it does, it is almost always fixed by one of the following:
● filter change with genuine Toyota filter and fluid refill with genuine Toyota T-IV
● getting the transmission fluid level up to the top of HOT area or slightly higher, with transmission hot, and on very level ground, while running in Park
● replacing failing ECU capacitors with the very rare correct low ESR, high ripple rejection, high temp premium Japanese type (which may or may not show any obvious leakage)
Old 01-31-14, 01:37 PM
Twista4004
Twista4004's Avatar
All this applicable to 1st gen? 93 specifically.
Old 01-31-14, 04:30 PM
LScowboyLS
LScowboyLS's Avatar
YES!
Old 02-01-14, 10:24 AM
Twista4004
Twista4004's Avatar
Cool thanks!
SuperCoupe400
Performance & Maintenance
07-29-09 04:49 AM
Rice
10-31-07 06:26 PM
RA40
Maintenance
06-01-06 09:58 AM
tmf2004
09-08-05 10:57 AM
1UZFE
12-11-03 08:54 PM
Quick Reply: 97' LS Tranny issue
