Loose Lower Side Molding!!
Old 01-29-14, 04:38 PM
EGGSNBACON
EGGSNBACON's Avatar
Default Loose Lower Side Molding!!
Hi guys, I'm new here. I recently discovered that my lower side molding on my front passenger side door was loose while cleaning away some of the salt stains from the winter storm . I was wondering if anyone knows how to fix it or do I need a replacement.
Thanks in advance
Old 01-29-14, 05:34 PM
SteveCraig
SteveCraig's Avatar
Without knowing what year RX you have, I would suggest finding out if it was a factory installed piece or perhaps the dealer. You may have warranty coverage on it but cannot confirm.
I put a set on our '10 last Summer & seems every third phrase in the directions was "clean surfaces well before application."
Old 01-29-14, 07:37 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
Is that the lower chrome strip on the exterior of the door? Hard to tell in the pics.
If that's the case, give the contact surfaces a good cleaning with 70% isopropyl alcohol (rubbing alcohol), and apply a quality double-sided exterior/automotive tape - Fixed.
Old 01-29-14, 08:18 PM
EGGSNBACON
EGGSNBACON's Avatar
sorry its a 2010 rx 350. Its the chrome strip on the side and where can I get this tape?
this picture is better
thanks
Old 01-30-14, 05:27 AM
ggebhardt
ggebhardt's Avatar
thanks
Look up body work supply stores in your area. It is possible that a local body shop will help you out, too. They sell this tape but do not know in what sizes. You can also get some industrial double sided tape at you local home improvement store but not sure it would be as good as what the body shops use.
Old 01-30-14, 07:35 AM
VVRX
VVRX's Avatar
thanks
If I were you I would just go to e-bay and type double sided tape-body side molding.
Old 01-30-14, 09:14 AM
vlad_a
vlad_a's Avatar
Any auto store will carry automotive grade 3M tape. I used it multiple times.
Old 01-30-14, 11:40 AM
oohpapi44
oohpapi44's Avatar
Tape is the way to go, just don't go cheap, the salt the city uses will eat through any low end stuff and you'll be back where you started, or worse.
Old 01-30-14, 03:24 PM
Sevn86
Sevn86's Avatar
I have 3M tape that i got at a local auto parts store and Home Depot and Lowe's carry it also.
Old 01-30-14, 03:30 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
3M automotive tape definitely good.
However, I've used the Lepage tape last couple years with great success on various home and automotive projects and it's very similar to the 3M's. On my RX, I taped the F-Sport badge on the rear 15 months ago and is still solidly glued like day 1 and this going through two winters, salt, dirt, etc. In fact the cheap Ebay knock-off badge is starting to rust and will probably disintegrate before the tape comes off! Similarly, I taped a similar badge on my IS (true OEM badge) 5 months ago and rock solid. In Canada, this is available at Home Depot, Lowes, Walmart, and Canadian Tire. Easy find, low cost (5-6$) and easy DIY
http://lepage.com/nomorenails/#d
Old 01-30-14, 03:59 PM
fastnoypi
fastnoypi's Avatar
Most Napa's carry 3m auto grade double-sided tape. You might also try asking a local auto body repair shop to sell a foot or so.
Old 01-31-14, 06:11 PM
EGGSNBACON
EGGSNBACON's Avatar
thanks guys. I bought some 3m tape from amazon, let you guys know how it turns out
Brianflo
GX - 1st Gen (2004-2009)
09-06-18 07:59 PM
CatManD3W
SC400 / 300 Classifieds
05-14-14 11:30 AM
e-man
07-11-04 12:59 PM
Quick Reply: Loose Lower Side Molding!!
